HiVi W6 Speaker Driver Midbass Shielded 45W 8 Ohm 86dB Ø16.5cm
Reference : 4791
64,90 €tax incl.
54,08 € tax excl.
https://www.audiophonics.fr/images2/Swans_Logo.gif
Characterized by their excellent performance / price ratio, and their powerful magnetic armored motor,
the speakers of the "W" series have all the necessary arguments for the construction of an acoustic system dedicated primarily to Multimedia and Home Cinema applications.
Cone in polymer compound covered with PPF film for maximum rigidity and lightness
Peripheral suspension in natural rubberloudspeaker to the loudspeaker, and participating inabsorbing parasitic vibrationsoriginating at the surface of the cone
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Powerful magnetic motor consisting of 2 magnets mounted in symmetrical and ventilated
Magnetic shielding authorizing the use of the unit in a Multimedia or Home Theater configuration
https://www.audiophonics.fr/images2/4791_SWANS-HIVI-W6_1.jpghttps://www.audiophonics.fr/images2/4791_SWANS-HIVI-W6_2.jpg
https://www.audiophonics.fr/images2/4791_SWANS-HIVI-W6_3.jpg
Specifications:
  • Nominal Impedance:8Ω
  • Resonant Frequency: 40Hz
  • Rated Power:45W
  • Maximum Power Output:90W
  • Sensitivity (2.83v / 1m): 86dB
  • Resistance DC:/ B>6.5Ω
  • Diameter Coil: 25mm
  • Length Coil:14.5mm
  • Mounting Type:Kapton
  • Composition Magnetic Circuit: Ferrite
  • Magnetic Shielding:/ B>Yes
  • BL:6.7
  • Hey :6.0mm
  • XmaX:4.3mm
  • Cms:913
  • Qms:3.04
  • Qes:0.64
  • Qts:0.52
  • Mms:17.1g
  • Sd:0.0139m2
  • Vas:25.1L
  • Recommended Type of Load: Bass Reflex
  • Recommended Load Volume: 22L
  • Recommended Cut-Off Frequency -3dB: 40Hz
  • Weight:2.5Kg
https://www.audiophonics.fr/images2/HiVi_Logo.jpg
https://www.audiophonics.fr/images2/4791_SWANS-HIVI-W6_4.jpg
HiVi W6:Dimensions
https://www.audiophonics.fr/images2/4791_SWANS-HIVI-W6_5.jpg
HiVi W6:Frequency Response
https://www.audiophonics.fr/images2/4791_SWANS-HIVI-W6_6.jpg
HiVi W6:Impedance Curve
Speaker Power (W RMS)45.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)165.0
Diaphragm typePolypropylene
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)4.3
Highest frequency (Hz)N/A
