MONACOR MS-130 Speaker Driver Midrange 40W 8 Ohm 94dB Ø13cm
This loudspeaker is a classic of the German designer.  An expressive and articulate midrange sound with an output of 94dB, ideal for three-way speaker design.  Inverted suspension, high temperature Kapton voice coil, low moving mass for optimal impulse behaviour make this model an ideal choice for high performance loudspeaker design.
Reference : 1205
47,90 €tax incl.
39,92 € tax excl.
Shipping date: 25-04-2025.
Monacor MS-130
Monacor MS-130 haut-parleur médium 40W 8Ω 94dB Ø13cm
Monacor MS-130 haut-parleur médium 40W 8Ω 94dB Ø13cm Monacor MS-130 haut-parleur médium 40W 8Ω 94dB Ø13cm
Product typeSpeaker driver
Speaker driver typeMedium
Impedance8Ω
Frequency rangefx-8000Hz
PowerRMS : 40W
Max : 80W
Sensitivity94dB/W/m
Voice coil diameterØ25.5mm
Magnet weight500g
Magnet diameterØ100mm
Thiele-Small Parameters
Resonant frequency (Fs)120Hz
Mechanical compliance of suspension (Cms)0.44mm/N
Diaphragm mass inc. airload (Mms)4g
Mechanical quality coefficient (Qms)5.23
Electromagnetic quality coefficient (Qes)1.06
Total quality coefficient (Qts)0.88
Compliance equivalent volume (Vas)3L
DC Resistance (Re)6.1Ω
Force factor (BL)4.2Tm
Voice coil inductance (Le)0.25mH
Max linear excursion (Xmax)±0.7mm
Surface area of cone (Sd)70cm²
Mounting informations
Cutout diameterØ120mm
Depth67mm
Dimensions135 x 135 x 70mm
Weight1.3kg
Speaker Power (W RMS)40.0
Speaker TypeMidrange
Impedance (Ω)8
Loudspeaker diameter (mm)130.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)94.0
Max Linear Excursion (Xmax) (mm)0.75
Lowest frequency (Hz)N/A
Highest frequency (Hz)8000
This loudspeaker is a classic of the German designer.  An expressive and articulate midrange sound with an output of 94dB, ideal for...
