MONACOR SP-60/8 Speaker Driver Midbass 30W 8 Ohm 90dB Ø10cm
Reference : 1197
21,50 €tax incl.
17,92 € tax excl.
Shipping date: 23-04-2025.
Medium Hi-Fi, 60 W MAX , 8 Ω (/ 8) and 4 Ω (/ 4) subwoofers. The Monacor SP60 speaker is a reference, a classic standard of small diameter speakers. It reconciles 90dB of output with a wide bandwidth.
The paper membrane has round corrugations avoiding the usual staining. Decompression and cooling by the core through the magnet allows a release of heat from the coil. Moreover, the loudspeaker is exemplary.
For miniature PC speakers, Hi-Fi, line array or any quality request in a restricted volume.
The best loads are obtained in quarter wave load (TQWT) and Bass Reflex. To be coupled with a small 19 / 20mm tweeter or a Monacor SP95SR ribbon tweeter.
Also suitable for DIY design of satellites in close loads with tweeters and a subwoofer.
Impedance (Z)8 Ω
Resonance frequency (fs)65 Hz
Maximum bandwidthf3-8000 Hz
Maximum power60 W MAX
Rated power (P)30 W RMS
Average sound pressure (1 W / 1 m)90 dB
Compliance susp. (Cms)0.8 mm / N
Moving mass (Mms)4 g
Mechanical overvoltage. (Qms)2.10
Electrical overvoltage (Qes)0.64
Fact. total surge (Qts) 0.49
Volume equ. (VAS)6 l
</ Span>DC resistance. (Re)3.3 Ω
Force factor (BxL)2.9 Tm
Inductance coil (The)0.2 mH
Coil diameter25.5 mm
</ Span>
Coil holderAlu
Linear Excursion (X MAX )±2 mm
Transmitting surface (Sd)55 cm 2
Magnet Weight 10 oz.
Weight0.9 kg
[Img-20584-left-thickbox_default]
Monacor SP60
Speaker Power (W RMS)30
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)100.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)90.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)8000
