MONACOR SPH-130 Speaker Driver Midbass 80W 8 Ohm 89dB
Reference : 1928
55,90 €tax incl.
46,58 € tax excl.
Shipping date: 25-04-2025.
Bass-midrange speaker, 80 W MAX, 8 Ω
Specially coated paper membrane, rubber suspension, the ideal speaker for 2-way or D'Appolito systems. Can also be used as a medium in multi-channel speakers.
Impedance (Z)
8 Ω
Resonance frequency (fs) 38 Hz
Maximum bandwidth f3-6000 Hz
Freq. cut. (Fmax). 3500 Hz
Maximum power 80 WMAX
Nominal power (P) 55WRMS
Pressure sound. (1W / 1m) 89 dB
Compliance susp. (Cms) 2.14 mm / N
Movable mass (Mms) 8.2 g
<span "= font-family: Verdana; font-size: small;">Mechanical resistance (Rms) 1.0 kg / s
Mechanical overvoltage. (Qms) 1.91
Electrical overvoltage (Qes) 0.39
Fact. total overvoltage (Qts) 0.32
Volume equ. (VAS) 22 l
DC resistance. (Re) 5.7 Ω
Inductance coil. (The) 0.5 mH
Coil diameter 25 mm
Coil support Alu
<span "= font-family: Verdana; font-size: small;">Height of winding 10 mm
Height gap 6 mm
Linear Excursion (X MAX)± 2 mm
Transmitting surface (Sd) 80 cm2
Flight. air displaced (Vd) 16 cm3
Force factor (BxL) 5.4 Tm
Ref. (No) 0.3%
Magnet diameter 72 mm
Magnet weight 8 oz.
<span "= font-family: Verdana; font-size: small;">cutting Ø 129 mm
Mounting depth 65 mm
dimensions 145 x 145 mm
Weight 0.75 kg
Recommended Min Volume
closed 6 l
bass reflex 12.5 l
Speaker Power (W RMS)80.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)130.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)6000
