MONACOR SPH-135C Speaker Driver Midbass 50W 8 Ohm 88dB Ø13cm
Reference : 831
99,00 €tax incl.
82,50 € tax excl.
Hi-Fi, 80 W MAX , 8 Ω Bass-Stereo Speaker
Parameters for exceptional bass reproduction. For 2-channel library, satellite or Appolito systems, bass-reflex or close.
 Impedance (Z) 8 Ω
 Resonance frequency (fs) 40 Hz
 Maximum bandwidth f3-8000 Hz
 Freq. cut. (Fmax). 4000 Hz
 Maximum power 80 W MAX
 Rated power (P) 50 W RMS
 Pressure sound. (1W / 1m) 88 dB
 Compliance susp. (Cms) 1.35 mm / N
 Moving mass (Mms) 12 g
 Mechanical resistance (Rms) 0.7 kg / s
 Mechanical overvoltage. (Qms) 4.48
 Electrical overvoltage (Qes) 0.43
Fact. total surge (Qts)0.39
 Volume equ. (VAS) 17 l
  </ Font>
 DC resistance. (Re) 6 Ω
 Inductance coil. (The) 0.75 mH
 Coil diameter 35.5 mm
 Coil holder Kapton
 Height winding 13 mm
 Air gap height 6 mm
 Linear Excursion (X MAX ) ± 3.5 mm
 Stransmission surface (Sd) 95 cm 2
 Flight. air displaced (Vd) 33.3 cm 3
 Force factor (BxL) 6.5 Tm
 Ref. (No) 0.2%
 Magnet diameter 100 mm
 Magnet Weight 17.7 oz.
 cutting Ø 122 mm
 Mounting depth 75 mm
 Dimensions 133 x 133 mm
 Weight 1.5 kg
 Recommended Min Volume
closed8 l
 bass reflex 17 l
Speaker Power (W RMS)50.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)130.0
Diaphragm typeCarbon fiber
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)3.5
Lowest frequency (Hz)N/A
Highest frequency (Hz)8000
Altoparlante Favoloso. Bassi e gamma media incredibile.
L'altoparlante è realizzato con grande attenzione ai dettagli. Cestello in alluminio, membrana in carbonio, magnete in ferrite e supporto bobina in Kapton. Il MONACOR SPH-135C sottoposto ai test ha fornito prestazioni piuttosto valide. I parametri rilevati sono sensibilmente difformi con quelli dichiarati dal costruttore. La frequenza di risonanza inferiore a 40 Hz e la ragguardevole tenuta in potenza permettono di ottenere prestazioni di rilievo in gamma bassa. Risposta in frequenza regolare a vantaggio della progettazione del filtro crossover che, par tali motivi sarà di semplice realizzazione. Qts e il BL elevati permettono una sensibilità di buon livello. E' un ottimo altoparlante, con apprezzabili caratteristiche che ne permettono l'impiego in sistemi a due vie di qualità. Ho personalmente adottato l'altoparlante in sistema bass-reflex, da 12 litri netti accordato a 50 Hz dove riesce a scendere in frequenza fino a 46,5 Hz (-3 db).
This review has been posted for MONACOR SPH-135C Speaker Driver Midbass 50W 8 Ohm 88dB Ø13cm
