MONACOR SPH-165 Speaker Driver Midbass 50W 8 Ohm 89dB Ø15cm
For all types of Hi-Fi uses, bass-reflex speakers, 2-way library or Appolito speakers.
Reference : 833
76,90 €tax incl.
64,08 € tax excl.
Shipping date: 25-04-2025.
MONACOR SPH-165
Speaker Driver Midbass 50W 8 Ohm Ø 15cm
MONCACOR SPH-165 Haut-Parleur Bas Medium 50W 8 Ohm Ø 15cm
Product typeMidbass Speaker Driver
Impédance8 Ohm
Resonant frequency (fs)33Hz
Max frequency responsef3-5000kHz
Cutoff frequency (fmax)3500Hz
Max power100W Max
ROMS power50W RMS
Sound pressure (1W/1m)89dB
Surround compliance (Cms)1.22mm/N
Mobile mass (Mms)16g
Mechanical resistance (Rms)1.6kg/s
Mechanical quality (Qms)2.02
Electronic quality (Qes)0.23
Total quality (Qts)0.21
Air mass equivalent volume (Vas)36l
DC Resistance (Re)6.5 Ohm
Coil inductance (Le)1.1mH
Coil diameter120mm
Coil supportAluminium
Coil height15mm
Entrefer height15mm
Max linear excursion (Xmax)+- 3.5mm
Emitting surface (Sd)137cm²
Displaced air volume (Vd)48cm3
Force factor (Bl)9.7Tm
Reference efficiency (No)0.5%
Magnet diameter120mm
Magnet weight836g
Cutout diameterØ 142mm
Depth89mm
DimensionsØ 165mm
Weight2.32kg
Bass Reflex> 10l
Speaker Power (W RMS)50.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)150.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)3.5
Lowest frequency (Hz)N/A
Highest frequency (Hz)5000
