Impedance (Z) | 8 Ω | |||||
Resonance frequency (fs) | 30 Hz | |||||
Maximum bandwidth | f3-6000 Hz | |||||
Freq. cut. (fmax). | 3500 Hz | |||||
Maximum power | 120 W MAX | |||||
Rated power (P) | 80 W RMS | |||||
Pressure sound. (1W / 1m) | 89 dB | |||||
Compliance susp. (Cms) | 1.71 mm / N | |||||
Moving mass (Mms) | 17 g | |||||
Mechanical resistance (Rms) | 0.7 kg / s | |||||
Mechanical overvoltage. (Qms) | 4.85 | |||||
Electrical overvoltage (Qes) | 0.33 | |||||
Fact. total surge (Qts) | 0.31 | |||||
Volume equ. (VAS) | 38 l | |||||
DC resistance. (Re) | 6 Ω | |||||
Inductance coil. (The) | 0, 7 mH | |||||
Coil diameter | 50 mm | |||||
Coil holder | glass fibers | |||||
Height winding | 17.5 mm | |||||
Air gap height | 8 mm | |||||
Linear Excursion (X MAX ) | ± 4.75 mm | |||||
Transmitting surface (Sd) | 127 cm 2 | |||||
Flight. air displaced (Vd) | 60.3 cm 3 | |||||
Force factor (BxL) | 7.6 Tm | |||||
Ref. (No) | 0.3% | |||||
Magnet diameter | 120 mm | |||||
Magnet Weight | 29.5 + 1.76 oz. | |||||
cutting | Ø 142 mm | |||||
Mounting depth | 90 mm | |||||
Dimensions | 165 x 165 mm | |||||
Weight | 2.5 kg | |||||
Recommended Min Volume | ||||||
closed | 9 l | |||||
bass reflex | 20 l |
Speaker Type |
Impedance (Ω) |
Loudspeaker diameter (mm) |
Diaphragm type |
Efficiency / Sensitivity (dB) |
Max Linear Excursion (Xmax) (mm) |
Speaker Power (W RMS) |
Lowest frequency (Hz) |
Highest frequency (Hz) |
