MONACOR SPH-170TC Speaker Driver Midbass 2x40W 2x8 Ohm 88dB Ø16.6cm
Reference : 838
56,90 €tax incl.
47,42 € tax excl.
 Bass-mid-speaker, 2 x 60 W MAX , 2 x 8 Ω
Double coil, polypropylene membrane, good attenuation of mediums, for small subwoofer or speakers 2 ways.
Klang + Ton 6/00
"A good speaker!"
 Impedance (Z) 2 x 8 Ω
 Resonance frequency (fs) 33 Hz
 Maximum bandwidth f3-5000 Hz
 Freq. cut. (fmax). 3000 Hz
 Maximum power 2 x 60 W MAX
 Rated power (P) 2 x40 W RMS
 Pressure sound. (1W / 1m) 88 dB
 Compliance susp. (Cms) 1.38 mm / N
 Moving mass (Mms) 16 g
 Mechanical resistance (Rms) 1.1 kg / s
 Mechanical overvoltage. (Qms) 2.98
 Electrical overvoltage (Qes) 0.48
 Fact. total surge (Qts) 0.41
 Volume equ. (VAS) 31 l
 DC resistance. (Re) 2 x 7.5 Ω / 3.8 Ω
 Inductance coil. (The) 2 x 0.6 mH / 0.6 mH
 Coil diameter 25.5 mm
 Coil holder Kapton
 Hwinding author 10.5 mm
 Air gap height 6 mm
 Linear Excursion (X MAX ) ± 2.25 mm
 Transmitting surface (Sd) 127 cm 2
 Flight. air displaced (Vd) 28.6 cm 3
 Force factor (BxL) 5.2 Tm
 Ref. (No) 0.2%
 Magnet diameter 100 mm
 Magnet Weight 13.3 oz.
 cutting Ø 142 mm
 Mounting depth 82 mm
 Dimensions Ø 166 mm
 Weight 1.4 kg
 Recommended Min Volume
 closed 16 l
 bass reflex 36 l
Speaker Power (W RMS)40.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)166.0
Diaphragm typePolypropylene
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)2.2
Lowest frequency (Hz)N/A
Highest frequency (Hz)5000
