Bass-midrange speaker, 100 W MAX , 8 Ω Specially coated paper membrane, rubber suspension, optimized aluminum bowl, the ideal speaker for 2-way systems. | |
Inductance coil. (The)
Speakers Speakers | |||
Impedance (Z) | 8 Ω | ||
Resonance frequency (fs) | 33 Hz | ||
Maximum bandwidth | f3-5000 Hz | ||
Freq. cut. (fmax). | 3000 Hz | ||
Maximum Power | 100 W MAX | ||
Rated power (P) | 60 W RMS | ||
Pressure sound. (1W / 1m) | 90 dB | ||
Compliance susp. (Cms) | 1.86 mm / N | ||
Moving mass (Mms) | 12.5 g | ||
pan> | |||
Mechanical resistance (Rms) | 1.3 kg / s | ||
Mechanical overvoltage. (Qms) | 1.98 | ||
Electrical overvoltage (Qes) | 0.43 | ||
Fact. total surge (Qts) | 0.35 | ||
Volume equ. (VAS) | 48 l | ||
DC resistance. (Re) | 5.7 Ω | ||
0.5 mH | |||
Coil diameter | 25 mm | ||
Coil holder | Alu | ||
Height winding | 10 mm | ||
Air gap height | 6 mm | ||
pan> | |||
Linear Excursion (X MAX ) | ± 2 mm | ||
Transmitting surface (Sd) | 137 cm 2 | ||
Flight. air displaced (Vd) | 27.4 cm 3 | ||
Force factor (BxL) | 6 Tm | ||
Ref. (No) | 0.4% | ||
Magnet diameter | 84 mm | ||
Magnet weights | 12.5 oz. | ||
cutting | Ø 162 mm | ||
Mounting depth | 70 mm | ||
Dimensions | 177 x 177 mm | ||
Weight | 1.2 kg | ||
Recommended Min Volume | |||
closed | 16 l | ||
bass reflex | 35 l |
Speaker Power (W RMS) | 60.0 |
Speaker Type | Midbass |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 175.0 |
Diaphragm type | Paper |
Efficiency / Sensitivity (dB) | 90.0 |
Max Linear Excursion (Xmax) (mm) | 2.0 |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | 5000 |
