I bought them a couple of weeks ago and now inserted them into my speakers. They do a fantastic job!
This SPH-200KE speaker from MONACOR is a low-midrange driver with a Kevlar fiber cone. It also features an aluminum bowl for 2- and 3-way systems. It delivers excellent bass reproduction across the entire Hi-Fi spectrum. Its nominal impedance is 8 ohms and its power handling rating is 80W.
Product type | Speaker Low Midrange |
Impedance | 8 ohm |
Frequency range | f3-4,500Hz |
Resonance frequency (fs) | 28Hz |
Nominal power | 80W |
Max. power | 120W |
SPL | 90dB/W/m |
Suspension compl. (CMS) | 0.89 mm/N |
Moving mass (Mms) | 37g |
Mech. Q factor (QMS) | 4.65 |
Electr. Q factor (Qes) | 0.41 |
Total Q factor (Qts) | 0.38 |
Equivalent volume (Vas) | 54l |
DC resistance (Re) | 6.2 Ω |
Force factor (BxL) | 9.90 Tm |
Voice coil induct. (Le) | Inductance bobine 0.75 mH |
Voice coil diameter | Ø50mm |
Voice coil former | Kapton |
Linear excursion (Xmas) | ± 4.75 mm |
Eff. cone area (SD) | 207 cm2 |
Magnet weight | 840g + 50g |
Magnet diameter | Ø 120mm |
Mounting cutout | Ø 182mm |
Mounting depth | 89mm |
Dimensions | Ø 212mm x 100mm |
Net weight | 2.72kg |
Package | 1x MONACOR SPH-200KE |
Speaker Power (W RMS) | 80.0 |
Speaker Type | Midbass |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 200.0 |
Diaphragm type | Kevlar |
Efficiency / Sensitivity (dB) | 90.0 |
Max Linear Excursion (Xmax) (mm) | 4.7 |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | 4500 |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Joscha O.
