MONACOR SPH-5M Speaker Driver Midbass 40W 8 Ohm 88dB 45Hz - 4000Hz Ø14cm
Reference : 5791
54,90 €tax incl.
45,75 € tax excl.
MONACOR SPH-5M 80 WMAX Hi-Fi Hi-Fi Woofer 8 Ω
  • High-fidelity Hi-Fi microphone with great travel, excellent reproduction quality
  • Damped polypropylene membrane, very low resonance
  • Solid aluminum bowl, 6-hole screw connection
  • Magnetic system with drilling of pole pieces and pole plate positioned at the rear
  • For universal use in TML bass reflex speakers and closed enclosures
  • Excellent as a medium in speakers 3 voies
Features:br>
Impedance (Z): 8 Ω
Resonant frequency (fs): 51 Hz
Maximum bandwidth: f3-4000 Hz
Maximum power: 80 WMAX
Nominal power (P): 40 WRMS
Average sound pressure (1 W / 1 m): 88 dB
Compliance susp. (Cms): 0.9 mm / N
Mobile mass (Mms): 10.7 g
Mechanical overvoltage. (Qms): 2.42
Electrical overvoltage (Qes): 0.49
Fact. total surge (Qts): 0.41
Volume equ. (VAS): 11.3 l
DC resistance. (Re): 6.12 Ω
Force factor (BxL): 6.56 Tm
Coil Inductor (Le): 0.54 mH
Coil diameter: Ø 25 mm
Coil Holder: Aluminum
Linear excursion (X MAX): ± 3.5 mm
Transmitting surface (Sd): 95 cm 2
Magnet weight: 620 g
Weight: 1.25 kg
https://www.audiophonics.fr/images2/5791/5791_SPH-5m_1.jpg
https://www.audiophonics.fr/images2/5791/5791_SPH-5m_3.jpg
https://www.audiophonics.fr/images2/5791/5791_SPH-5m_2.jpg
Speaker Power (W RMS)40.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)140.0
Diaphragm typePolypropylene
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)4.0
Lowest frequency (Hz)45
Highest frequency (Hz)4000
