MONACOR SPH-60X Bi-Cone Speaker Driver Full Range 30W 8 Ohm 89dB Ø13cm
Reference : 5830
46,90 €tax incl.
39,08 € tax excl.
Shipping date: 24-04-2025.
MONACOR SPH-60X Bicone Broadband Speaker 13cm
Wide-band speaker, bicone, 60 W MAX , 8 Ω.
Suspension half-roll in impregnated fabric, decompression and cooling by the core. Oversized magnet. Excellent linearity in the treble range. For universal use. The loudspeaker of the CT193 and CT194 speaker kits.
Klang & Ton:
"The best of all times, it has never been sold so oftenbroadband ... Unusually poor in color change, an almost unbelievable bass playback for such a small broadband. "
https://www.audiophonics.fr/images2/5830/5830_SPH-60X_1.jpg
https://www.audiophonics.fr/images2/5830/5830_SPH-60X_2.jpg
https://www.audiophonics.fr/images2/5830/5830_SPH-60X_3.jpg
https://www.audiophonics.fr/images2/5830/5830_SPH-60X_4.jpg
Speaker Power (W RMS)30
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)130.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)1.3
Lowest frequency (Hz)N/A
Highest frequency (Hz)20000
Martin Kunchev
I waited a long time, but it's worth it. Thank you Audiophonics. Excellent sound and sensitivity throughout the range. Good strength for its size. They fit perfectly in my quad system. However, a notch filter is needed to cut the frequencies between 900 and 6kHz. Even though they are mounted in a suspended ceiling they sound better than in a box. I strongly recommend
This review has been posted for MONACOR SPH-60X Bi-Cone Speaker Driver Full Range 30W 8 Ohm 89dB Ø13cm
