60 W Hi-Fi Woofer MAX, 4Ω (/ 4)
Specifications Speakers | |||
Impedance (Z) | 4 Ω | ||
Resonance frequency (fs) | 53 Hz | ||
Maximum bandwidth | f3-8000 Hz | ||
Maximum power | 60 WMAX | ||
Nominal power (P) | 30 WRMS | ||
Average sound pressure (1 W / 1 m) | 90 dB | ||
Compliance susp. (Cms) | 1.95 mm / N | ||
Movable mass (Mms) | 4.3g | ||
Mechanical overvoltage. (Qms) | 2.01 | ||
Electrical overvoltage (Qes) | 0.46 | ||
Fact. total overvoltage (Qts) | 0.37 | ||
Volume equ. (VAS) | 8 l | ||
ReDC resistance. (Re) | 3.3 Ω | ||
Force factor (BxL) | 3.3 Tm | ||
Inductance coil (Le) | 0.3 mH | ||
Coil diameter | 25.5 mm | ||
Coil support | Alu | ||
Linear Excursion (X MAX) | ± 2 mm | ||
Transmitting surface (Sd) | 55 cm2 | ||
Magnet weight | 10 oz. | ||
Weight | 0.9 kg |
Speaker Power (W RMS) | 60.0 |
Speaker Type | Midbass |
Impedance (Ω) | 4 |
Loudspeaker diameter (mm) | 110.0 |
Diaphragm type | Carbon fiber |
Efficiency / Sensitivity (dB) | 90.0 |
Max Linear Excursion (Xmax) (mm) | 2.0 |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | 8000 |
