Hi-Fi, 60 W MAX , 8 Ω (/ 8) Subwoofers with PVC / Carbon membrane. Decompression and cooling by the core. For 2-way library or Appolito systems. SPP-110/4 = 4 Ω SPP-110/8 = 8 Ω |
Speakers Speakers | |||
Impedance (Z) | 8 Ω | ||
Resonance frequency (fs) | 55 Hz | ||
Maximum bandwidth | f3-8000 Hz | ||
Maximum power | 60 W MAX | ||
Rated power (P) | 30 W RMS | ||
Average sound pressure (1 W / 1 m) | 90 dB | ||
Compliance susp. (Cms) | 1.89 mm / N | ||
Moving mass (Mms) | 4.4 g | ||
Mechanical overvoltage. (Qms) | 2.01 | ||
Electrical overvoltage (Qes) | 0.46 | ||
Fact. total surge (Qts) | 0.37 | ||
Volume equ. (VAS) | 8 l | ||
DC resistance. (Re) | 6.5 Ω | ||
Force factor (BxL) | 4.6 Tm | ||
Inductance coil (The) | 0.4 mH | ||
Coil diameter | 25.5 mm | ||
Coil holder | Alu | ||
pan> | |||
Linear Excursion (X MAX ) | ± 2 mm | ||
Transmitting surface (Sd) | 55 cm 2 | ||
Magnet Weight | 10 oz. | ||
Weight | 0.9 kg |
Speaker Power (W RMS) | 30 |
Speaker Type | Midbass |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 110.0 |
Diaphragm type | Carbon fiber |
Diaphragm type | PVC |
Efficiency / Sensitivity (dB) | 90.0 |
Max Linear Excursion (Xmax) (mm) | 2.0 |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | 8000 |
