SUPRAVOX 165 GMF Speaker Driver Midbass 35W 8 Ohm 96dB 60Hz - 10kHz Ø 16cm
Reference : 32
299,00 €tax incl.
249,17 € tax excl.
This loudspeaker incorporates the 165LB features, the dome suppression allows to release the low register, the ogive allowing a better spatialization of the medium. It complements ideally with the tweater TW 2-20.
Sensitivity 1 W / 1m to Fs97 dBDrill hole diameter160 mm
Bandwidth60 to 10 kHzProHP Founder85 mm
Impedance8 ohmsfs64 Hz
Power consumption RMS35 WRe5.5 ohms
Weight1.9 kgqt0.38
Suspension5-ply paperQe0.4
Linear Excursion6 mm Qm 9
Ferrite magnet96 mmVas33 L
Magnetic field1.4 Tbl5.8
HP Diameter185 mmcms0.6
Bowl ThicknessAlu 10mmmms
5 g
distance mounting holes175 mmsd
165 cm²
Speaker Power (W RMS)35.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)160.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)96.0
Max Linear Excursion (Xmax) (mm)6.0
Lowest frequency (Hz)60
Highest frequency (Hz)10000
