SUPRAVOX 165 LB Speaker Driver Full Range 35W 4 Ohm 95dB 60Hz - 19kHz Ø 16 cm
By buying this product you get 25 loyalty points
Reference : 31
259,00 €tax incl.
215,83 € tax excl.
This loudspeaker, created in 2001, can be baffled in rather small volumes, in bass reflex or TQWT it can do without subwoofer for a fast reproduction and powerful low frequencies up to 50 Hz.
This is the ideal speaker for creating a pair of library loudspeaker. It can also be used in wide-band midrange in quality 3-way speakers.
Sensitivity 1 W / 1m to Fs  95 dBDrill hole diameter  160 mm
Bande passerine60 to 19 kHzHP Depth85 mm
imimpedence8 ohmsfs64 Hz
Puimax. RMS  35 WRe4 ohms
Poids1.9 kgqt  0.42
SUSPENSION5-ply paperQe0.46
Excursion linear  6 mmQm4.8
Havemantle ferrite  96 mmVas33 L
chmagnetic amp1.4 Tbl4.7
diameter HP  185 mmcms0.7
Epsalad bowl  Alu 10mmmms5.5 g
distance mounting holes175 mmsd165 cm²
Speaker Power (W RMS)35.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)160.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)95.0
Max Linear Excursion (Xmax) (mm)6.0
Lowest frequency (Hz)60
Highest frequency (Hz)19000
Download
supravox-165lbbr.pdf
datasheet Bass Reflex165 LB SUPRAVOX
Download (28.2k)
