SUPRAVOX 215 GMF Speaker Driver Midbass 40W 8 Ohm 97dB 40Hz - 5000Hz Ø 21 cm
By buying this product you get 47 loyalty points
Reference : 29
479,00 €tax incl.
399,17 € tax excl.
This high-bandwidth, high-output loudspeaker offers you a very fast and pleasant listening. Ideal listening with a low power amp (tube or transistor) of about 10W, it also supports higher powers for use in subwoofers. In a flat panel, it will reinforce the 215 RTF with the same degree of reproduction precision, to add a bass reinforcement and ensure a comfortable and balanced listening. In column TQWT it will bring out all the finesse of your favorite listening. In case RJ, bass reflex or symmetrical, it will be a grave of accompaniment of the most precise. This HP can be coupled with a 1-inch engine mounted on our horn. Cut to 500Hz the response curve will be straight to ± 2 dB from 35 to 20 000Hz.
Suspension :5 plis papier
Excursion linéaire :+/- 3,7 mm
Aimant :ferrite 120 mm
Champ magnétique :1,1 T
Diamètre HP :236mm
Saladier :Aluminium
Distance trous de fixation :223mm
Diamètre perçage enceinte :208mm
Profondeur HP :115mm
Fs :54 Hz
Re :8 Ω
Le 1 kHz :0,73 mH
Qts :0,36
Qe :0,38
Qm :8,57
Vas :60 L
Bl :9,7
Mms :13 g
Sd :253 cm²
Sensibilité (2,83V/1m) :96dB
Sensibilité (1W/1m) :96dB
Bande passante :50Hz-4KHz
Impédance :8 Ω
Puissance max. RMS :40 W
Speaker Power (W RMS)40.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)210.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)97.0
Max Linear Excursion (Xmax) (mm)3.7
Lowest frequency (Hz)40
Highest frequency (Hz)5000
