Coming from the 215 RTF, a legendary speaker, broadband and high-performance, the bicone model offers you exceptional installation in the field of exceptional warmth and exceptional consistency.
Thanks to its very wide bandwidth it can be mounted in loudspeakers a channel without filtering. Handcrafted, equipped with a powerful magnetic circuit, a very light mobile equipment and an exponential membrane, it reaches a level of accuracy of reproduction worthy of the best installations.
Mounted in TQWT speakers, resonators or rear headphones, the response ranges from 50Hz to 18000Hz to ± 3dB.
It is already a reference in many audiophiles who consider it a wonderful standard for the setting of multi-channel multi-amplification systems
Sensitivity 1 W / 1m to Fs | 96 dB | Drill hole diameter | 212 mm |
Bandwidth | 50 to 20kHz | HP Depth | 100 mm |
Impedance | 8 ohms | fs | 52 Hz |
Max. RMS | 35 W | Re | 6.5 |
Weight | 2.8 kg | qt | 0.53 |
Suspension | 3-ply paper | Qe | 0.6 |
Linear Excursion | 4 mm | Qm | 5 |
Ferrite magnet | 120 mm | Vas | 75 L |
Magnetic field | 1.5 T | bl | 5.3 |
HP Diameter | 224 / 237mm | cms | 0.8 |
Bowl Thickness | <sVerdana, Arial, Helvetica, sans-serif, font-size: small; "> Alu 10mm | mms | 9.5 g |
Distance fixing holes | 227 mm | sd | 263 cm² |
Speaker Power (W RMS) | 35.0 |
Speaker Type | Full range |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 210.0 |
Efficiency / Sensitivity (dB) | 96.0 |
