SUPRAVOX 285-2000 mk2 Speaker Driver Full Range 70W 8 Ohm 101dB Ø 28cm
By buying this product you get 123 loyalty points
Reference : 40
1 239,00 €tax incl.
1 032,50 € tax excl.
Low / Medium Speaker - Central Alnico Motor
285-2000mk2
The 285-2000 speaker reference now has a new central Alnico 5 motor to replace the former base ring motor.
This new configuration allows the membrane to capture the full power of the magnet. The mk2 version can thus achieve the same performance as previously in a more compact format.
This new profile induces less distortion and effectively supresses the magnetic constraints at the back of the speaker.
The moving equipment stays exactly the same, which preserves all the qualities that have become the signature of 285-2000 such as an excellent response in mid / bass, transparency and sound frequency balance.
This high-performance loudspeaker is ideal for medium-low frequencies in active multiway systems.
When mounted in plan panel, it can neatly accompany a 215-2000 speaker and offers ideal specifications for a low pavilion.
Bandwidth :45Hz-7 KHz
impedance:
Max. RMS:45W
suspension:3 paper plies
linear excursion:3.5mm
Alnico Magnet:3.5 Kg
Magnetic field :1.4 T
HP Diameter:290 / 307mm
bowl thickness:Alu 8mm
Distance mounting holes:24mm
pregnant drilling diameter:280mm
HP Depth:180mm
fs:60Hz
Re:6.5Ω
Qts:0.31
Qe:0.32
Qm:7
Vas:135 L
Bl:10.45Tm
cms:0.5
mms:14.5 g
sd:442.77 cm2
Speaker Type
  • Midbass
Impedance (Ω)
  • 8
Loudspeaker diameter (mm)
  • 280.0
Diaphragm type
  • Paper
Efficiency / Sensitivity (dB)
  • 101.0
Max Linear Excursion (Xmax) (mm)
  • 8.0
Speaker Power (W RMS)
  • 70.0
Lowest frequency (Hz)
  • 45
Highest frequency (Hz)
  • 7000
