By buying this product you get 32 loyalty points
285 GMF
This high-bandwidth, high-output loudspeaker offers you a very fast and pleasant listening.
Ideal listening with a low power amp (tube or transistor) of about 10W, it also supports higher powers for use in subwoofers.
In a flat panel, it will reinforce the 215 RTF with the same degree of reproduction precision, to add a bass reinforcement and ensure a comfortable and balanced listening.
In column TQWT it will bring out all the finesse of your favorite listening. In case RJ, bass reflex or symmetrical, it will be a grave of accompaniment of the most precise.
This HP can be coupled with a 1-inch engine mounted on our horn. Cut to 500Hz the response curve will be straight to ± 2 dB from 35 to 20 000Hz.
Sensitivity 1 W / 1m to Fs | 99 dB | a, Arial, Helvetica, sans-serif; font-size: small; "> Fs | 47Hz |
Bandwidth | 40 to 7kHz | Re | 6.5 ohms |
Impedance | 8 ohms | qt | 0.38 |
Power consumption RMS | 70 W | Qe | 0.39 |
Weight | 3.5 kg | Qm | 8 |
Suspension | 3-ply paper | Vas | 150 L |
Linear Excursion | 8 mm | bl | 10.7 |
Ferrite magnet | 120 mm | Cms | 0.6 |
Magnetic field | 1.4 T | mms | 20 g |
HP Diameter | 290 / 307mm | sd | 471 cm² |
Thickness of bowl | Aluminum 8mm | ||
HP Depth | 120 mm | ||
Distance fixing holes | 290 mm | ||
Drill hole diameter | 270 mm |
Speaker Power (W RMS) | 70.0 |
Speaker Type | Midbass |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 280.0 |
Diaphragm type | Paper |
Efficiency / Sensitivity (dB) | 99.0 |
Max Linear Excursion (Xmax) (mm) | 8.0 |
Lowest frequency (Hz) | 40 |
Highest frequency (Hz) | 7000 |
