By buying this product you get 123 loyalty points
This high-performance (96 dB) bass speaker offers you a fast, deep and very pleasant listening. Its exponential membrane ensures a wide bandwidth with a natural cut-off at 4000 Hz without accidents at the end of the band. Its engine made up of a ring of 3.5 Kg in Alnico makes it possible to obtain the field necessary to achieve such sensitivity. These qualities allow it to be directly coupled with a 1-inch engine mounted on our roof. Mounted in a bassreflex or jensen box, cut at 500Hz, the response curve will be straight to ± 2 dB up to the final frequency of the 1-inch motor. | ||||||||||||||||||||||||||||||||||||||||
Speaker Type |
Impedance (Ω) |
Loudspeaker diameter (mm) |
Diaphragm type |
Efficiency / Sensitivity (dB) |
Max Linear Excursion (Xmax) (mm) |
Speaker Power (W RMS) |
Lowest frequency (Hz) |
Highest frequency (Hz) |
