SUPRAVOX 400 EXC Speaker Driver Full Range 120W 8 Ohm 90/99dB 23Hz - 4000Hz Ø 40cm
By buying this product you get 123 loyalty points
Reference : 45
1 239,00 €tax incl.
1 032,50 € tax excl.
An audiophile quality bass driver: the 400-2000 EXC offers very high response quality (fast and wideband) because it is built around the same membrane as the 400-2000. Its advantage is the possibility of adjusting these parameters thanks to a powerful electromagnetic motor. Adaptable to many speakers, it requires an external power supply (ideal from 10 to 14V for 5A).
For audiophiles in quest of absolute, the 400-2000 EXC is available in silver reel (99.99%).
Sensitivity 1 W / 1m to Fs90 to 99 dBFood0 to 13 Volts DC.
Bandwidth23 to 4 kHzMagnetic field0 to 1.6 T
Impedance8 ohmsHP Diameter404 mm
Power consumption RMS120 WBowl ThicknessAlu 10mm
Weight10.7 kgDistance fixing holes382 mm
SuspensionCanvasDrill hole diameter358 mm
Resonance Frequency23 HzHP Depth215 mm
Linear Excursion10 mmsd
855 cm²
fs
mms
cms
Re DC
25 Hz
66 g
0.5
6.5
Food
5 V
7 V
9 V
11 V
13 V
14 V
15 V
Vas434444440433438439429
qt
1,011
0598
0431
0309
0236
0215
0195
Qe
1082
0627
0446
0317
0242
0219
0200
Qm
15349
13531
12801
11.490
10.060
9,935
9334
bl
8381
10,879
12964
15496
17.626
18491
19596
SPL ref
91.5
94
95.4
96.8
98.1
98.7
99.1
Speaker Type
  • Midbass
Impedance (Ω)
  • 8
Loudspeaker diameter (mm)
  • 400.0
Diaphragm type
  • N/A
Efficiency / Sensitivity (dB)
  • 99.0
Max Linear Excursion (Xmax) (mm)
  • 10.0
Speaker Power (W RMS)
  • 120.0
Lowest frequency (Hz)
  • 23
Highest frequency (Hz)
  • 4000
