TANG BAND T-2121SD Speaker Driver Module Full Range Aluminium 6W 4 Ohm 79dB 78Hz - 20kHz
This Tang-Band T1-2121SD wideband loudspeaker module integrates both an active loudspeaker with a diameter of Ø46mm and a passive radiator. This design allows it to cover a wide frequency range, from 78Hz to 20kHz, while keeping a compact format.
Reference : 14044
38,90 €tax incl.
32,42 € tax excl.
Shipping date: 03-04-2025.
Tang-Band T1-2121SD
Tang-Band T1-2121SD Module Haut-Parleur Large Bande Aluminium 6W 4Ω 79dB 78Hz-20kHz
This Tang-Band T1-2121SD wideband loudspeaker module integrates both an active loudspeaker with a diameter of Ø46mm and a passive radiator. This design allows it to cover a wide frequency range, from 78Hz to 20kHz, while keeping a compact format. The module supports an RMS power of 6W (12W max) at 4Ω and will be ideal for designing small multimedia speakers or sound bars.
Product typeSpeaker driver module
Speaker driver typeFull range
Module compositionActive speaker + Passive radiator
Active speaker diameterØ46mm
Cone materialComposite Aluminium with Elastomer
Case materialPP Composite
Voice coil diameterØ28mm
Impedance4Ω
PowerRMS : 6W
Max : 12W
Frequency response78Hz - 20kHz
Sensitivity (@ 1W/1m)79dB
Lowest resonant frequency (Fo)78Hz
Design suggestionHigh-Pass filter, 87Hz, -12dB/oct
Dimensions157 x 54 x 29.5mm
Speaker Power (W RMS)6.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)46.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)79.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)78
Highest frequency (Hz)20000
This Tang-Band T1-2121SD wideband loudspeaker module integrates both an active loudspeaker with a diameter of Ø46mm and a passive...
