TANG BAND W4-2315 Coaxial Speaker Driver
Tang Band's W4-2315 coaxial driver offers extensive sound reproduction thanks to its Ø11.4cm full-range diaphragm and Ø2cm tweeter. It has a power handling capacity of 30W, a bamboo fibre cone for the full-range driver, an aluminium-magnesium alloy cone for the tweeter and a rubber suspension for good performance.
Reference : 19630
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 24-04-2025.
Tang Band W4-2315 Coaxial Speaker Driver with Tweeter 30W 4Ω 88dB Ø11.4cm
TANG BAND W4-2315 : Front view
TANG BAND W4-2315 : Dimensions and SPL versus Frequency
Product typeCoaxial speaker
Speaker typeFull Range
Diaphragm materialPaper
Aluminium-magnesium alloy
Surround materialRubber
Magnetic systemNeodymium
Nominal impedance
DCR impedance3.6Ω
Sensitivity88dB
Frequency response65Hz - 40kHz
Free air resonance65Hz
Voice coil diameter32mm
Air gap height12mm
Rated power RMS30W
Max. power60W
Force factor (BL)6.20TM
Moving mass8.09g
Suspension compliance733.04 uMN¯¹
Effective piston area0.0069 M²
Levc0.09 mH
Zo50Ω
Maximum linear peak (X-Max)2.8mm
Compliance volume (Vas)4.96L
Total quality factor (Qts)0.29
Mechanical quality factor (QMS)3.68
Electrical quality factor (Qes)0.31
External diameterØ114mm
Cutout diameter63.87mm
Depth76.87mm
Mounting bolt diameterØ145.17mm
Mounting holes6
Package1x Tang Band W4-2315
Speaker Power (W RMS)30
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)114.0
Diaphragm typeComposite alloy
Diaphragm typePaper
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)2.8
Lowest frequency (Hz)65
Highest frequency (Hz)40000
TANG BAND W4-2315 Coaxial Speaker Driver with Tweeter 30W 4Ω 88dB 65Hz-40kHz Ø11.4cm
Tang Band's W4-2315 coaxial driver offers extensive sound reproduction thanks to its Ø11.4cm full-range diaphragm and...
