TANG BAND W5-1611SAF Speaker Driver Full Range 28W 8 Ohm 90dB 60Hz-20kHz Ø12.7cm
The Tang Band W5-1611SAF is a 12.7cm diameter full range driver, ideal for integration into compact loudspeakers. It features a robust polypropylene diaphragm supported by a rubber surround and is powered by a suspension motor.
Reference : 17296
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 03-04-2025.
Tang Band W5-1611SAF Haut-Parleur Large Bande 28W 8 Ohm 90dB 60Hz-20kHz Ø12.7cm
Tang Band W5-1611SAF Haut-Parleur Large Bande 28W 8 Ohm 90dB 60Hz-20kHz Ø12.7cm Tang Band W5-1611SAF Haut-Parleur Large Bande 28W 8 Ohm 90dB 60Hz-20kHz Ø12.7cm
Speaker driver typeFull range
Nominal diameterØ127mm (5")
Power handlingRMS: 28W
Max: 56W
Impedance8Ω
Frequency response60Hz - 20kHz
Sensitivity90dB
Voice coil diameterØ25.4mm
Weight-
Overall external dimensionsØ157*87.4mm
Magnet weight-
Resonant frequency (fS)60Hz
DC Resistance (RE)6.3Ω
Electrical quality factor (QES)0.52
Mechanical quality factor (QMS)2.80
Total quality factor (QTS)0.44
Suspension equivalent air volume (VAS)11.69L
Maximum impedance (Zmax)40Ω
Voice coil inductance (LE)0.023mH
Force factor (B·l)5.53T·m
Suspension mechanical resistance (RMS)0.8N·s/m
Suspension mechanical compliance (CMS)1307µm/N
Moving mass (MMD)5.3g
Moving mass including airload (MMS)5.99g
Surface of the diaphragm (SD)94cm²
Effective diaphragm diameterØ10.9m
Maximum linear excursion (Xmax)±3mm
Displacement volume at Xmax (VD)28.2cm³
Efficiency (η₀)0.47%
Efficiency bandwidth product (EBP)115
Materials
Diaphragm materialPolypropylene
Surround materialRubber
Magnet materialFerrite
Mounting informations
Overall external diameterØ157mm
Cutout diameterØ131mm
Total depth87.4mm
Mounting bolt diameterØ145mm
Number of mounting holes4
Speaker Power (W RMS)15.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)76.0
Diaphragm typePolypropylene
Efficiency / Sensitivity (dB)76.0
Max Linear Excursion (Xmax) (mm)5.0
Lowest frequency (Hz)55
Highest frequency (Hz)2000
Un très bon large bande
Un copain m'a fait découvrir ce petit haut parleur qui a une très belle restitution du bas médium entre autre.
Je l'utilise dans des enceintes bibliothèque en 2 voies avec un tweeter AMT, après essai en clos et bass reflex, c'est la deuxième solution que j'ai retenue, en clos il y a un manque dans le grave et il faudrait rajouter une troisième voie.
En utilisation en 2 voies, on a un gain sur la définition, détails, ... en comparaison sans tweeter.
Un excellent haut parleur que je recommande vivement.
This review has been posted for TANG BAND W5-1611SAF Speaker Driver Full Range 28W 8 Ohm 90dB 60Hz-20kHz Ø12.7cm
The Tang Band W5-1611SAF is a 12.7cm diameter full range driver, ideal for integration into compact loudspeakers. It features a robust...
