TANG BAND W3-871SC Speaker Driver Full Range 12W 8Ω 86dB Ø9.3cm
Tang Bang's W3-871SC full-range driver offers extensive sound reproduction thanks to its 93mm-diameter diaphragm. It has a power handling capacity of 12W, a silver paper diaphragm and a Santoprene suspension for optimum performance.
Reference : 19263
36,90 €tax incl.
30,75 € tax excl.
Shipping date: 24-04-2025.
TANG BAND W3-871SC : Front view
TANG BAND W3-871SC : Dimensions and SPL versus Frequency
Product typeSpeaker
Speaker typeFull Range
Diaphragm materialSilver Paper
Surround materialSantoprene
Magnetic systemFerrite
Nominal impedance8 Ω
DCR impedance6.6 Ω
Sensitivity86 dB
Frequency response110Hz - 20kHz
Free air resonance110 Hz
Voice coil diameter18 mm
Air gap height6 mm
Rated power RMS12W
Max. power25W
Force factor (BL)3.51 TM
Moving mass2g
Suspension compliance1133 uMN¯¹
Effective piston area0.0032 M²
Levc0.75 mH
Zo38 Ω
Maximum linear peak (X-Max)0.5 mm
Compliance volume (Vas)1.65 L
Total quality factor (Qts)0.59
Mechanical quality factor (QMS)3.4
Electrical quality factor (Qes)0.71
External diameterØ93mm
Cutout diameter71.5mm
Depth60.5mm
Mounting bolt diameterØ84.5mm
Mounting holes4
Package1x TANG BAND W3-871SC
Speaker Power (W RMS)12.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)93.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)0.5
Lowest frequency (Hz)110
Highest frequency (Hz)20000
Tang Bang's W3-871SC full-range driver offers extensive sound reproduction thanks to its 93mm-diameter diaphragm. It has a power handling...
