TANG BAND W4-2142 Speaker Driver Full Range 25W 8Ω 88dB Ø12.55cm
Tang Bang's W4-2142 full-range driver offers extensive sound reproduction thanks to its 12.55cm-diameter diaphragm. It has a power handling capacity of 25W, a paper diaphragm and a Santoprene suspension for optimum performance.
Reference : 19264
69,90 €tax incl.
58,25 € tax excl.
Shipping date: 24-04-2025.
TANG BAND W4-2142 Speaker Driver Full Range 25W 8Ω 88dB Ø12.5cm
TANG BAND W4-2142 : Front view
TANG BAND W4-2142 : Dimensions and SPL versus Frequency
Product typeSpeaker
Speaker typeFull Range
Diaphragm materialPaper
Surround materialSantoprene
Magnetic systemFerrite
Nominal impedance8 Ω
DCR impedance6.3 Ω
Sensitivity88 dB
Frequency response60Hz - 20kHz
Free air resonance60 Hz
Voice coil diameter25.4 mm
Air gap height10 mm
Rated power RMS25W
Max. power50W
Force factor (BL)5.41 TM
Moving mass4.61 g
Suspension compliance1390 uMN¯¹
Effective piston area0.0057 M²
Levc0.022 mH
Zo40 Ω
Maximum linear peak (X-Max)2.4 mm
Compliance volume (Vas)6.41 L
Total quality factor (Qts)0.33
Mechanical quality factor (QMS)2.20
Electrical quality factor (Qes)0.39
External diameterØ125.5mm
Cutout diameter95mm
Depth81.5mm
Mounting bolt diameterØ115mm
Mounting holes4
Package1x TANG BAND W4-2142
Speaker Power (W RMS)25.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)125.5
Diaphragm typePaper
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)2.4
Lowest frequency (Hz)60
Highest frequency (Hz)20000
tang band w4
Excellent large bande de 10cm , montées dans des enceintes de type "métronome" l'écoute est très dynamique et le grave bien restitué (mieux que le fostex 108 sigma) excellente qualité de fabrication ,une petite merveille .
This review has been posted for TANG BAND W4-2142 Speaker Driver Full Range 25W 8Ω 88dB Ø12.5cm
Tang Bang's W4-2142 full-range driver offers extensive sound reproduction thanks to its 12.55cm-diameter diaphragm. It has a power handling...
