TECTONIC BMR TEBM65C20F-8 Speaker Driver Full Range Paper 20W 8 Ohm 81dB 80Hz - 20kHz Ø 8.9cm
Tectonic's BMR range consists of wideband loudspeakers designed to cover a very large part of the audible audio spectrum. Thus, the TEBM65C20F-8 has an extended frequency response from 80Hz to 20kHz and a wide directivity.
Reference : 13588
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 29-04-2025.
TECTONIC BMR TEBM65C20F-8 Haut-Parleur Large Bande 20W 8 Ohm 81dB 80Hz - 20kHz Ø 8.9cm
Tectonic's BMR range consists of wideband loudspeakers designed to cover a very large part of the audible audio spectrum. Thus, the TEBM65C20F-8 has an extended frequency response from 80Hz to 20kHz and a wide directivity. In addition, Tectonic combines flexible wave technology and piston operation to ensure high audio performance despite a very small speaker format.
Dimensions
Product typeFull range speaker driver
Nominal diameter8.9cm
PowerRMS : 20W
Max : 40W
Impedance8 Ohm
Frequency response80Hz - 20kHz
Sensitivity81dB 1W/1m
Thiele-Small Parameters
ParameterDescriptionMin.Typ.Max.Unité
ReDC Resistance-10%7.41+10%Ohm
LeInductance (@ 10kHz)-10%0.058+10%mH
BLForce factor-4.34-Tm
FsResonant frequency-20%92+20%Hz
dDrvCoil diameter-25.4-mm
MmsMoving mass-5.77-g
CmsCompliance-0.52-mmN-1
RmsSurround mechanical resistance-0.56-Nsm-1
XmaxMax linear excursion-3.5-mm
SdSurface area of cone-37.2-cm²
VasEquivalent compliance volume-1.01-L
QmsMechanical quality factor-5.93-
QesElectrical quality factor-1.31-
QtsTotal quality factor-1.07-
Material
Diaphragm materialPaper
Magnet materialFerrite
Mounting informations
Total external diameter10.8cm (4.25")
Cutout diameter8.64cm (3.4")
Depth4.77cm (1.88")
Mouting hole number6
Optimum cabinet size
Sealed volume0.1 ft³
Sealed F384Hz
Vented volume0.2 ft³
Vented F350Hz
Speaker Power (W RMS)20.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)89.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)81.0
Max Linear Excursion (Xmax) (mm)3.5
Lowest frequency (Hz)80
Highest frequency (Hz)20000
Ma commande
Bonjour,
j'aurais aimé être informé avant la finalisation de la commande qu'il y avait un réapprovisionnement.
This review has been posted for TECTONIC BMR TEBM65C20F-8 Speaker Driver Full Range Paper 20W 8 Ohm 81dB 80Hz - 20kHz Ø 8.9cm
Tectonic's BMR range consists of wideband loudspeakers designed to cover a very large part of the audible audio spectrum. Thus, the...
