VISATON BF 32 Speaker Driver Full Range 2W 8 Ohm 78dB 150Hz-20kHz Ø3.2cm
The Visaton BF 32 is a small full range loudspeaker with a diameter of 3.2cm. It offers a wide and balanced frequency response and good low frequency reproduction. It is particularly suitable for use in equipment where space is limited and depth is thin.
Reference : 16735
12,50 €tax incl.
10,42 € tax excl.
Shipping date: 24-04-2025.
Visaton bf 32
Speaker Driver Full Range 2W 8Ω 78dB 150Hz-20kHz Ø3.2cm
Visaton BF 32 Haut-Parleur Large Bande
Visaton K 50 WP Haut-Parleur Large Bande 2W 8Ω 84dB 180Hz-17kHz Ø5cm
Product typeSpeaker driver
Speaker driver typeFull range
Handling powerRMS : 2W
Max : 5W
Impedance8Ω
Diaphragm materialPlastic
Basket materialMetal
Frequency response150Hz - 20kHz
SPL78dB (1W/1m)
Resonant frequency280Hz
Voice coil diameterØ20mm
Winding height3mm
Cutout diameterØ31.5mm
Weight28g
Speaker Power (W RMS)2.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)32.0
Diaphragm typePlastic
Efficiency / Sensitivity (dB)78.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)150
Highest frequency (Hz)20000
The Visaton BF 32 is a small full range loudspeaker with a diameter of 3.2cm. It offers a wide and balanced frequency response and good low...
