VISATON FRS 8 M Speaker Driver Full Range 30W 8 Ohm 88dB 100Hz-20kHz Ø8cm
The Visaton BF 32 is a small full range loudspeaker with a diameter of 3.2cm. It offers a wide and balanced frequency response and good low frequency reproduction. It is particularly suitable for use in equipment where space is limited and depth is thin.
Reference : 16736
16,90 €tax incl.
14,08 € tax excl.
Shipping date: 24-04-2025.
Visaton FRS 8 M
Speaker Driver Full Range 2W 8Ω 78dB 150Hz-20kHz Ø3.2cm
Visaton FRS 8 M Haut-Parleur Large Bande
Visaton FRS 8 M Haut-Parleur Large Bande 30W
Product typeSpeaker driver
Speaker driver typeFull range
Handling powerRMS : 30W
Max : 50W
Impedance8Ω
Diaphragm materialPaper
Basket materialMetal
Frequency response100Hz - 20kHz
SPL88dB (1W/1m)
Resonant frequency125Hz
Voice coil diameterØ20mm
Cutout diameterØ75mm
Weight0.5kg
Speaker Power (W RMS)30
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)80.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)2.5
Lowest frequency (Hz)100
Highest frequency (Hz)20000
The Visaton BF 32 is a small full range loudspeaker with a diameter of 3.2cm. It offers a wide and balanced frequency response and good low...
