VISATON FRWS 5 Speaker Driver Full Range 4W 8 Ohm 84dB 150Hz-20kHz Ø5cm
The Visaton FRWS 5 is a full range speaker with a diameter of 5cm and a square front panel. It offers a balanced frequency response above 250Hz with accurate highs and an omnidirectional sound distribution. It can be used as a midrange driver in floorstanding loudspeakers, but will also find its place in many other audio projects.
Reference : 16612
13,50 €tax incl.
11,25 € tax excl.
Visaton FRWS 5
Speaker Driver Full Range 4W 8Ω 84dB 150Hz-20kHz Ø5cm
Visaton FRWS 5 Haut-Parleur Large Bande 4W 8Ω 84dB 150Hz-20kHz Ø5cm
Visaton FRWS 5 Haut-Parleur Large Bande 4W 8Ω 84dB 150Hz-20kHz Ø5cm Visaton FRWS 5 Haut-Parleur Large Bande 4W 8Ω 84dB 150Hz-20kHz Ø5cm Visaton FRWS 5 Haut-Parleur Large Bande 4W 8Ω 84dB 150Hz-20kHz Ø5cm
Product typeSpeaker driver
Speaker driver typeFull range
Handling powerRMS : 4W
Max : 10W
Impedance8Ω
Frequency response150Hz - 20kHz
SPL84dB (1W/1m)
Linear excursion±2mm
Resonant frequency250Hz
Front panel thickness2mm
Voice coil diameterØ14mm
Winding haight2.7mm
Cutout diameterØ45mm
Weight100g
Speaker Power (W RMS)4.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)50.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)84.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)150
Highest frequency (Hz)20000
The Visaton FRWS 5 is a full range speaker with a diameter of 5cm and a square front panel. It offers a balanced frequency response above 250Hz...
