VISATON K 64 WP Speaker Driver Full Range 2W 8 Ohm 86dB 200Hz-15kHz Ø6.4cm
The Visaton K 64 WP is a small full range loudspeaker with a diameter of 6.4cm, with a plastic frame and diaphragm. It offers a wide frequency response and a beautiful sound reproduction. It is particularly suitable for use outdoors or in humid areas.
Reference : 16610
7,50 €tax incl.
6,25 € tax excl.
Shipping date: 16-04-2025.
Visaton K 64 WP
Speaker Driver Full Range 2W 8Ω 86dB 200Hz-15kHz Ø6.4cm
Visaton K 64 WP Haut-Parleur Large Bande 2W 8Ω 86dB 200Hz-15kHz Ø6.4cm
Visaton K 64 WP Haut-Parleur Large Bande 2W 8Ω 86dB 200Hz-15kHz Ø6.4cm Visaton K 64 WP Haut-Parleur Large Bande 2W 8Ω 86dB 200Hz-15kHz Ø6.4cm Visaton K 64 WP Haut-Parleur Large Bande 2W 8Ω 86dB 200Hz-15kHz Ø6.4cm
Product typeSpeaker driver
Speaker driver typeFull range
Handling powerRMS : 2W
Max : 3W
Impedance8Ω
Diaphragm materialMylar
Basket materialABS
Frequency response200Hz - 15kHz
SPL86dB (1W/1m)
Linear excursion±1mm
Resonant frequency300Hz
Front panel thickness2mm
Voice coil diameterØ10mm
Winding height2.5mm
Cutout diameterØ60mm
Weight50g
Speaker Power (W RMS)2.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)64.0
Diaphragm typePlastic
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)1.0
Lowest frequency (Hz)200
Highest frequency (Hz)15000
The Visaton K 64 WP is a small full range loudspeaker with a diameter of 6.4cm, with a plastic frame and diaphragm. It offers a wide frequency...
