VISATON SL 87 FE Speaker Driver Full Range 10W 8 Ohm 87dB 75Hz - 18kHz Ø8.5cm
The Visaton SL 87 FE is a wide-range loudspeaker with a diameter of Ø8.5cm. It has a plastic membrane, a rubber suspension and benefits from high efficiency thanks to its large ferrite magnet. Its frequency response is very balanced and its reproduction accurate. Compact and very affordable, it will be perfect for designing small DIY speakers.
Reference : 14144
20,90 €tax incl.
17,42 € tax excl.
Shipping date: 25-04-2025.
Visaton SL 87 FE
Visaton SL 87 FE Haut-Parleur Large Bande 10W 8 Ohm 87dB 75Hz - 18kHz Ø8.5cm
Product typeSpeaker driver
Speaker driver typeFull range
PowerRMS : 10W
Maximum : 15W
Impedance8Ω
Frequency response75Hz - 18kHz
Sensitivity87dB 1W/1m
Voice coil diameterØ20mm
Wiring height6mm
Protection markingIP64
Min/Max operating temperature-40°C / 80°C
Thiele-Small Parameters
DC Resistance (Re)7.2Ω
Mechanical quality coefficient (Qms)3.3
Electrical quality coefficient (Qes)0.82
Total quality coefficient (Qts)0.65
Compliance equivalent volume (Vas)1.53L
Resonant frequency (Fs)120Hz
Surface area of cone (Sd)37.3cm²
Diaphragm mass inc. airload (Mms)2.4g
Force factor (BL)3.95Tm
Mounting informations
Cutout diameterØ80mm
Weight486g
Speaker Power (W RMS)10.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)85.0
Diaphragm typePlastic
Efficiency / Sensitivity (dB)87.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)75
Highest frequency (Hz)18000
The Visaton SL 87 FE is a wide-range loudspeaker with a diameter of Ø8.5cm. It has a plastic membrane, a rubber suspension and benefits from high...
