Housing 250 x 200 x 120 front face 10 mm Silver
HIFI 2000 Housing with dissipators are ideal to build HiFi amplifiers or any kind of high-power device. The massive aluminum / steel frame is very sturdy and long-lasting. The HIFI 2000 dissipators series offer different sizes regarding electronic casing. While being versatile enough to be used in a variety of projects, it remains easy to mount and to use.
In addition to large dissipators with vertical wings (40mm), this housing has many opening on its top-plate in order to maximise heat circulation. The materials used in the building process are also very efficient at lowering termal stress.
Spécifications | |||
Dimensions | Height | Width | Depth |
Internal | 120 | 250 | 200 |
External | 124 | 330 | 213 |
Type | Mounting housing |
Front cover | Aluminum 10mm thick |
Back cover | Anti-scratch Steel 1mm thick |
Side covers | 2 dissipators 40 x 200mm Anodized aluminum |
Top & bottom covers | Anti-scratch Steel 1mm thick |
Weight | 4.3 kg |
