1MII LAVAUDIO DS100 Portable Headphone Amplifier DAC CS43198 32bit 384kHz DSD256
1Mii unveils with the DS100 a powerful and affordable headphone amplifier and portable DAC combo to provide you with a quality sound reproduction, whether for listening on the road or at home. Its digital to analog conversion stage uses a CS43198 DAC chip with an optimized clock system.
Reference : 16013
89,00 €tax incl.
74,17 € tax excl.
1Mii DS100
1Mii DS100 Amplificateur casque DAC portable CS43198 32bit 384kHz DSD256
1Mii unveils with the DS100 a powerful and affordable headphone amplifier and portable DAC combo to provide you with a quality sound reproduction, whether for listening on the road or at home. Its digital to analog conversion stage uses a CS43198 DAC chip with an optimized clock system, offering precise and transparent sound reproduction, as well as very good measured performances: THD+N of only 0.0003% and SNR higher than 115dB. Moreover, this DAC allows it to support high sampling rates, up to PCM 32bit 384kHz and DSD256.
On its side, its amplification stage allows it to develop a power of 156mW under 16Ω or 87.5mW under 32Ω, with a dynamic range of 118dB, a noise level under 2µV and an output amplitude of 1.7Vrms. A power that it develops with efficiency and musicality, favoring a coherent restitution on the whole frequency range.
The DS100 is also compatible with Android and iOS devices but can also be used as a computer DAC.
Product typePortable headphone amplifier and DAC
Input1x USB-C
Output1x Jack 3.5mm
DAC ChipCS43198
USB InterfaceCT7601
DSD up to DSD256
THD+N0.0003%
SNR121dB
Output power156mW @ 16Ω
87.5mW @ 32Ω
Dynamic range118dB
Noise level< 2µV
Output amplitude2Vrms
Output impedance0.15Ω
Supply voltage5VDC
Dimensions58 x 19 x 6.5mm
Input
  • USB
Output
  • Jack 3.5mm
Color
  • Black
Remote Control
  • No
1Mii unveils with the DS100 a powerful and affordable headphone amplifier and portable DAC combo to provide you with a quality sound reproduction,...
