Ibasso D14 BUSHMASTER Headphone Amplifier / USB DAC ES9018K2M 32bit/384kHz DSD
By buying this product you get 22 loyalty points
Reference : 10204
229,00 €tax incl.
190,83 € tax excl.
The iBasso D14 BUSHMASTER is a versatile and compact mobile device with extraordinary Audio capabilities in line with its predecessors and the reputation of the brand.
Both powerful headphone amplifier and high-end USB DAC (connected to a computer as well as an Android or iDevice terminal), it can work in DAC + AMPLI, in stand-alone AMPLI, or as a stand-alone DAC (output function line).
This extremely compact "Combo" is also comfortable in sedentary use connected to a microcomputer rather than roaming.
With the size of a credit card and a low weight, it enters the circle of ultra compact Hi-Fi devices combining the functions of DAC and high-quality amplifier.
The iBasso D14 BUSHMASTER proves to be the ideal companion for any music lover who owns Smartphone or Tablet wishing to enjoy very high resolution audio files.
Features:/ Strong>
  • DAC: ESS Converter Sabrg ES9018K2M
  • Interface USB 2.0 Asynchronous XMOS
  • Supports PCM files up to 32bit 384kHz and DSD256
  • Frequency response: 17Hz - 20kHz to +/- 1dB (DAC), 17Hz - 100kHz to +/- 1dB (Amplifier)
  • Signal Noise Ratio: 115dB (DAC line out), 116dB (Amplifier)
  • THD: 0.0018% at 1kHz / -10dBF (DAC), 0.0012% at 1kHz / Max. (Amp)
  • Output Impedance: 0.1 ohm
  • Output Power: 400mW + 400mW at 32 Ohm
  • Recommended impedance (headphones): 8 to 300 Ohm
  • Gain: +3 / + 9dB (Amp)
  • Lithium-Polymer battery rechargeable via USB (4.2 V)
  • Charging time: 5 h
  • Autonomy: 13 h (Ampl + DAC), 25 h (Amp only)
  • External power supply: 5V DC
  • Chassis Aluminum
  • Anodized Silver
  • Dimensions: 60x104x20mm
  • Weight: 150g
  • Comes with a USB cable, interconnect jack cable, rubber feet, two elastic support and an OTG USB cable
  • Compatible with Android (from 4.2), Windows, Mac OS and iDevices with photo kit.
Illustration: Model version black color.
InputJack 3.5mm
OutputJack 3.5mm
ColorSilver
Ibasso D14 Bushmaster
Le produit le plus satisfaisant que j'ai jamais acheté car il a une qualité à savoir qu'il fonctionne tant sur un smartphone Androïd que sur n'importe lequel des baladeurs par la coaxiale contrairement au Cayin C5 qui est un DAC prévu uniquement pour le téléphone et non sur un baladeur comme il m'avait été confirmé par le SAV du site.
Je regrette de ne pas trouver un manuel d'emploi en français et des explications concernant les multiples possibilités de connexion.
L'importateur est défaillant et le droit de la consommation aussi.
This review has been posted for Ibasso D14 BUSHMASTER Headphone Amplifier / USB DAC ES9018K2M 32bit/384kHz DSD
