TOPPING NX7 Portable Headphone NFCA Amplifier Balanced Black
The Topping NX7 is a compact and powerful portable amplifier, offering a beautiful precision and richness of sound. It is equipped with a new NFCA amplifier circuit specifically designed for portable amplification systems. Its low power consumption allows for long battery life, while ensuring excellent audio performance, with a THD+N 0.00007% and an SNR of 135dB. This module is powerful enough to accompany both demanding headphones and extremely sensitive earphones.
Reference : 15863
179,00 €tax incl.
149,17 € tax excl.
Topping NX7
Topping NX7 Amplificateur Casque Portable NFCA Symétrique Noir
High power in a compact size
The NX7 is capable of delivering a power of 2x180mW under an impedance of 300Ω, with what's more an adjustable gain on three levels: -13.8dB, -0.1dB or 13.9dB. Thus, it will have no trouble powering high-impedance headphones. Moreover, even with a high power of 200mW, the distortion remains extremely low with a measurement at 0.00008%. The background noise of the NX7 is less than 0.3µV and therefore perfectly inaudible. Finally, its impedance of only 0.1Ω ensures a sound reproduction without coloration, even with high sensitivity headphones.
Robust design & Dual output.
The NX7's components are clad in a sturdy aluminum chassis with flanges to protect the connectors and plugs, while preventing unwanted volume changes.
On the output side, the NX7 provides both a balanced 4.4mm jack output and a single-ended 3.5mm jack output, adaptable to any listening equipment.
An important battery life
Totally optimized, the NX7 offers a consequent autonomy being able to reach 20 hours in the case of a use with a low or average gain. In high gain mode, the autonomy remains important with its 10h in reading. It integrates for that a battery of not less than 4000mAh.
Product typePortable headphone amplifier
Amplification moduleNFCA
Input1x Jack 3.5mm
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
Measurements
Single-ended Jack 3.5mm outputBalanced Jack 4.4mm output
THD+N @ 1kHz (A-Weighting)< 0.00008% @ Output = 200mW, 32Ω
< 0.00007% @ Output = 83mW, 300Ω
THD @ 20Hz-20kHz (90kBW)< 0.001% @ Output = 200mW, 32Ω
< 0.0002% @ Output = 83mW, 300Ω
SNR @ Max out, 1kHz (A-Weighting)135dB135dB
SNR @ 50mV Output level, 1kHz104dB104dB
Dynamic range @ 1kHz (A-Weighting)135dB135dB
Frequency response20Hz-40kHz (±0.1dB)20Hz-40kHz (±0.1dB)
Output level7.4Vpp @ G=L
11Vpp @ G=M
21Vpp @ G=H
7.4Vpp @ G=L
11Vpp @ G=M
21Vpp @ G=H
Measured noise level (Audio Precision) @ A-Weighting< 0.7µVrms @ G=L
< 0.7µVrms @ G=M
< 2.0µVrms @ G=H
< 0.7µVrms @ G=L
< 0.7µVrms @ G=M
< 2.0µVrms @ G=H
Actual noise level* @ A-Weighting< 0.3µVrms @ G=L
< 0.3µVrms @ G=M
< 1.3µVrms @ G=H
< 0.3µVrms @ G=L
< 0.3µVrms @ G=M
< 1.3µVrms @ G=H
Channel crosstalk @ 1kHz-91dB-96dB
Input sensitivity13Vrms @ G=L
4Vrms @ G=M
1.5Vrms @ G=H
13Vrms @ G=L
4Vrms @ G=M
1.5Vrms @ G=H
Gain-13.8dB @ G=L
-0.1dB @ G=M
13.9dB @ G=H
-13.8dB @ G=L
-0.1dB @ G=M
13.9dB @ G=H
Output impedance< 0.1Ω< 0.1Ω
Output power2x1200mW @ 16Ω, THD+N <0.1%
2x1400mW @ 32Ω, THD+N <0.1%
2x820mW @ 64Ω, THD+N <0.1%
2x180mW @ 300Ω, THD+N <0.1%
2x90mW @ 600Ω, THD+N <0.1%
Adapter impedance> 8Ω
* The actual noise level is obtained by boosting the noise of the NX7 by 40dB using a low noise amplifier before the APx555B, then dividing the measured value by 100.
Dimensions135 x 70 x 16mm
Package1x Toping NX7
1x Jack 3.5mm cable
1x USB-A to USB-C cable
2x Rubber bands
1x Rubber pad
Topping NX7 Amplificateur Casque Portable NFCA Symétrique Noir Topping NX7 Amplificateur Casque Portable NFCA Symétrique Noir
InputJack 3.5mm
OutputJack 4.4mm
OutputJack 3.5mm
3 reviews
Etonnant Nx7 !
Couplée avec le Dx170, vous prenez un gap sonore bluffant, la profondeur de scène et énorme, ainsi qu`une basse présente et bien texturée, la largeur de scène prend aussi de l`ampleur, le tout et magique ! Un achat de haute qualité.
This review has been posted for TOPPING NX7 Portable Headphone NFCA Amplifier Balanced Black
Etonnant Nx7 !
Sur mon DX170 couplee avec le N
Excellent - will beat many desktop amplifiers
Very impressed with this portable headphone amplifier which will easily beat many desktop amplifiers for sound quality & power. It easily drives my HiFiMan Sundara planar magnetics & Sennheiser HD600s. The sound quality is fractionally behind my Topping A90 desktop amplifier which is amazing given that it is portable. The battery life claims are totally realistic - I measured 20-hours listening at reasonable levels using my HD600s on medium-gain and just under 10-hours using my Sundaras on high-gain. If only it had an on-bord DAC, it would be a no-brainer. However, even using an Apple Lightning to 3.5mm cable and streaming Tidal from my iPhone, the sound is neutral (not boring), detailed, powerful and enjoyable. I consider this to be a bargain and is highly recommended. If you need the on-board DAC, the Chord Mojo remains the one to beat - until Topping launch their own (NX7+on-board DAC).
The Topping NX7 is a compact and powerful portable amplifier, offering a beautiful precision and richness of sound. It is equipped with a new NFCA...
