XDUOO XP-2 BAL Portable Balanced DAC Headphone Amplifier ES9018K2M Bluetooth 5.0 aptX 32bit 384kHz DSD256
The xDuoo XP-2 BAL is a portable amplifier and balanced DAC that is easy to carry and offers great performances with your high definition audio files. It uses an ESS ES9018K2M conversion chip working in a decoding circuit supporting sample rates up to 32bit 384kHz / Native DSD256, Bluetooth 5.0 with aptX-HD & LDAC and works with a USB interface XMOS XU208.
Reference : 17424
179,00 €tax incl.
149,17 € tax excl.
xDuoo XP-2 Bal
Portable Headphone Amplifier Balanced DAC ES9018K2M Bluetooth 5.0 32bit 384kHz DSD256
xDuoo XP2 BAL Amplifier Balanced DAC
The xDuoo XP-2 BAL is a portable amplifier and a balanced DAC that is easy to carry and offers great performances with your high definition audio files. It uses an ESS ES9018K2M conversion chip working in a decoding circuit supporting sample rates up to 32bit 384kHz / Native DSD256, Bluetooth 5.0 with aptX-HD & LDAC and works with a USB interface XMOS XU208.
XDUOO XP-2 BAL
XDUOO XP-2 PRO V2
USB interface
XMOS XU208
XMOS XU208
Max sampling rate (USB)
32-bit 384kHz DSD256
Bluetooth Protocols
SBC, AAC, APTX, APTX LL, APTX HD, LDAC
Balanced
Yes
NO
A new amplifier circuit
Different from the traditional integrated amplification circuit, the XP-2 BAL embeds the new OP+BUF structure allowing a balanced output power pushed to 320mW. Its two onboard chips, the Qualcomm CSR8675 and the XMOS XU208, guarantee the retransmission of clean and deep sounds, whether by Bluetooth or USB type C port.
xDuoo XP-2 BAL DAC Bluetooth 5.0
Bluetooth 5.0 & NFC pairing
The XP-2 BAL supports the latest Bluetooth 5.0 version bringing many improvements in wireless transmission. Thus, the range allowed by this evolution is doubled, and the transmission rate can now reach 2Mbps. As for consumption, nothing to fear since this new version has no impact on this parameter.
This speed allows you to enjoy high quality audio playback and extremely stable transmission. In addition, this version also allows the device to detect radio frequency interference in the 2.4GHz band in order to modify the communication channel accordingly to preserve transmission performance.
It should also be noted that it supports, thanks to the Qualcomm CSR 8675 bluetooth chip, the Bluetooth protocols SBC, AAC, APTX, APTX LL, APTX HD, LDAC,, allowing excellent interoperability with your high fidelity sources as well as an excellent transmission rate and stability for accurate audio reproduction.
Finally, with the NFC pairing function, you can link your devices in one click and won't be bothered by a complicated pairing protocol.
Interface USB XMOS XU208
The xDuoo amplifier / DAC benefits from a high-performance XMOS XU208 USB interface. This works asynchronously and also supports high resolution files up to 32bit 356kHz in PCM and native DSD256. Something to really enjoy your favorite songs, without limit.
xDuoo interface USB SA9123
xDuoo XP-2 BAL compatible android et iOS
High compatibility
The xDuoo XP-2 Bal can be combined with many audio sources, be they Android, iOS, MacOSX, Windows, so you can enjoy its amplification and conversation power, as well as its amazing sound reproduction, whether you're on the go or at home. In addition, to allow you to enjoy the best of your music.
In the case of the use with an iPhone it will be necessary to use the Camera Kit of Apple.
When using with an Android device, simply use an OTG USB cable.
An amplifier and DAC with multiple features
2 levels gain
The xDuoo XP-2 Bal, to fit all headphone types, headphones and EMI, offers two-level gain adjustment. A switch on the side of the unit changes from +3dB to +9dB.
DAC Out
Micro USB Input, 3.5mm Jack Auxiliary or Bluetooth 5.0, the XP-2 Bal offers many possible inputs. But you can also connect the XP-2 to active speakers, to enjoy only its high quality Digital to Analog conversion.
Embed microphone
A built-in audio microphone supports voice communication when the XP-2 BAL is used with its Bluetooth input using Qualcomm's CVC8.0 noise reduction technology.
TypePortable Headphone amp
Bluetooth receiver
DAC ChipES9018K2M
USB ChipXMOS XU208
Bluetooth ChipCSR8675
Bluetooth Norm5.0
Bluetooth protocolsSBC, AAC, APTX, APTX LL, APTX HD, LDAC
BatteryLithium-ion polymere 2200mAh 3.7V
Output powerUnbalanced = 180mW @ load 32Ω
Balanced = 320mW @ load 32Ω
Frequency responseUSB/Bluetooth: 20Hz-20kHz
AUX: 10 Hz-100kHz
Sampling rateUSB PCM: 16-32bit/44.1-384kHz
USB DXD: 24-32 bit/352.8-384kHz
USB DSD: DOP/NATIVE mode, DSD64-256
BT: 16-32bit/44.1 -96kHz
Gain+3/9dB
Signal to noise ratioUnbalanced = 110dB
Balanced = 112dB
CrosstalkUnbalanced = 75dB
Balanced = 92dB
Charging cycle≤ 3 hours
THD+NUnbalanced = 0.002%@1kHz
Balanced = 0.001%@1kHz
Dimensions105 x 55 x 15mm
Weight150g
OutputJack 4.4mm
OutputJack 3.5mm
ClassN/A
The xDuoo XP-2 BAL is a portable amplifier and balanced DAC that is easy to carry and offers great performances with your high definition audio...
