AIYIMA H1 Portable headphone amplifier 2xNE5532 20hz-20khz 170mw @ 32Ω
AIYIMA offers with the H1 a compact and powerful portable headphone amplifier. With an AUX input, it is an ideal companion for use with a wide range of devices; phones, computers, tablets, etc. It has a classic 3.5mm jack output compatible with most of your listening devices such as headphones or active speakers.
Reference : 17724
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 06-05-2025.
AIYIMA H1
AIYIMA H1 Amplificateur casque portable 2x NE5532 20hz-20khz 170mw @ 32Ω
AIYIMA offers with the H1 a compact and powerful portable headphone amplifier. With an AUX input, it is an ideal companion for use with many devices; phone, computer, tablet, etc. It integrates a classic 3.5mm jack output compatible with the majority of your listening devices such as headphones or active speakers.
Two OPA NE5532 chips
This headphone amplifier with these two OPA NE5532 chips reaches an output power of 170mW @ 32Ω .
If you want the OPA chips are easily replaceable.
An interchangeable 800 mAh battery
The AIYIMA H1 comes with an 800 mAh battery that will allow you to enjoy 4 hours of listening. This battery is easily replaceable to improve the performance of this headphone amplifier.
EVERSOLO H1 DAC Amplificateur Casque Portable ES9281AC MQA 32bit 384kHz DSD256
Efficient connectors
The H1 charges via a USB-C port and has an input and output both in 3.5mm Jack.  In addition, a volume control is also present and also serves as an on/off button.
SpEcifications
Product typePortable headphone amplifier
OPA chips2x NE 5532
Input1x Jack 3.5mm (AUX)
Ouput1x Jack 3.5mm
Output power170mW @ 32Ω
Frequency response20hz-20Khz (±0.1db)
SNR ≥111db
Distorsion0.03%
Load impedance16-300Ω
Working voltage2.8V-4.2V
Charging voltageDC5V (USB-C)
Battery capacity800mah (Lithium batterie)
Maximum volume working time4h
Dimensions110 x 62 x 17mm
Net Weight123g
Gross weight210g
Package1x AIYIMA H1
1x USB-C to USB-A charging cable
1x 3.5mm jack to 3.5mm jack cable
1x Accessory tool set
Input
  • AUX
Output
  • Jack 3.5mm
Color
  • Black
Class
  • N/A
Remote Control
  • No
AIYIMA offers with the H1 a compact and powerful portable headphone amplifier. With an AUX input, it is an ideal companion for use with a wide...
