E1DA 9038D6K Balanced Headphone Amplifier USB DAC ES9038Q2M AD8397 32bit 384kHz DSD256
The E1DA 9038D6K is a high performance USB DAC and portable headphone amplifier combo. Compact and lightweight, it incorporates excellent components to ensure a quality sound reproduction, marked by an incredible precision and richness.
Reference : 17305
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 03-04-2025.
E1DA 9038D6K
E1DA 9038SG3 DAC USB Amplificateur Casque Symétrique ES9038Q2M AD8397
Thus, its aluminum shell conceals an ES9038Q2M DAC chip supporting high sampling rates, up to 32bit 384kHz PCM and DSD256. The 9038D6K works without battery and is directly powered by your playback device (smartphone, DAP...) but offers a particularly low power consumption. The input is on a USB-C connector where the output is on a single-ended Jack 3.5mm. The USB interface chip is a ComTrue CT7601 whose code is 100% proprietary, allowing to maximize the Android and DSD compatibility.
E1DA Tweak9038 app
E1DA's Tweak9038 application allows you to control harmonic distortion compensation, select a Nyquist filter, manage the Master Clock frequency and much more. Most of the parameters can be set dynamically depending on the hardware volume, audio data rate, etc. An ideal tool to adapt the sound reproduction of your DAC according to your listening and your hardware.
Application E1DA Tweak9038 Android
Product typeUSB DAC
Headphone amplifier
InputUSB-C
OutputJack 3.5mm
DAC chipES9038Q2M
Amplification chipAD8397
DSD up to DSD256
Output impedance0.07Ω @ 1kHz
Output power180mW @ 32Ω, 1kHz, THD=1%
120mW @ 16Ω, 1kHz, THD=1%
Frequency response5Hz - 80kHz (+0.05/-1dB)
SNR126dB(A)
Dynamic range126dB(A)
THD< 0.0001% @ 1kHz, -0.5dBFS, 22Hz-22kHz
THD+N< 0.00018% @ 32Ω, 1kHz, -2.5dBFS, 22Hz-22kHz
Crosstalk-85dB @ 1kHz 32Ω
Supply voltage5V via USB
Housing materialAnodized aluminum
Dimensions48*22*9mm
Weight12g
OutputJack 3.5mm
DAC / ADC ChipES9038Q2M
Max sampling rate384kHz
Max sampling rateDSD256
The E1DA 9038D6K is a high performance USB DAC and portable headphone amplifier combo. Compact and lightweight, it incorporates excellent...
