EVERSOLO H1 DAC Portable Headphone Amplifier ES9281AC Pro MQA 32bit 384kHz DSD256
EVERSOLO offers with the H1 a compact and powerful portable DAC and headphone amplifier combo. With a USB-C input, it is an ideal companion for use with a current smartphone. It incorporates a classic 3.5mm jack output compatible with most of your listening devices.
3.5 / 5
Reference : 17505
59,00 €tax incl.
49,17 € tax excl.
Last items in stock !
Shipping date: 22-04-2025.
EVERSOLO H1
EVERSOLO H1 DAC Amplificateur Casque Portable ES9281AC MQA 32bit 384kHz DSD256
HI-Res Audio certification
The HI-Res Audio certification guarantees a listening quality superior to MP3 and CD, this is a guarantee of a level of quality of high fidelity digital audio reproduction superior to the current standard.
An ES9281AC Pro DAC chip for great performance
The digital/analog conversion stage uses an ES9281AC Pro DAC chip. This ensures good sound resolution and low distortion. It also allows low energy consumption, noise reduction and an SNR of up to 130dB. In addition, it supports high resolution audio streams, up to PCM 32bit 384kHz and DSD256.
Moreover, MQA (Master Quality Authenticated) technology allows the EVERSOLO H1 to reveal the resolution of original MQA files.
For MQA rendering support it will be necessary to use the EVERSOLO H1 with MQA compatible applications such as Tidal and Roon.
LDO integrated circuit and low power consumption
The LDO allows the amplification circuit to deliver high current and significantly reduce noise.
Power consumption control allows the EVERSOLO H1 to avoid overheating. When no headphones are inserted the decoding circuit is automatically disabled, so this also preserves the battery of your phone for example. Added to this is a smart POP crackling sound breaker to reduce "POP" crackling noise and prevent damage to your headphones or hearing.
Classic connectors (USB-C and 3.5mm Jack)
Thanks to its USB type C input and support for the UAC 2.0 protocol, the EVERSOLO H1 does not require any reader to be installed and allows Plug and Play on most of your devices (phones, tablets and computers).
The 3.5mm headphone jack is gold-plated, which ensures a reliable connection and strong resistance to oxidation.
A compact and pleasant design
The compact, metallic and shiny case returns a feeling of softness to the touch and is easy to clean.
We will also note the presence of an intuitive multicolor RGB indicator that can detect audio file formats and display 4 colors accordingly:
    • Red = Device connected
    • Green = DSD
    • Blue = PCM
    • Purple = MQA
SpEcifications
Product typeDAC and headphone amplifier
DAC ChipESS ES 9281AC Pro
Inputs1x USB-C
Outputs1x Jack 3.5mm
Output power13mW @ 300Ω
62mW @ 16-32Ω
Supported sampling ratesPCM : 32bit 384kHz
DSD : DSD256
MQA
Frequency response+0.3dB (20Hz-40kHz)
THD+N-109dB
SNR130dB (20Hz-20kHz)
GEnEral
Dimensions50 x 20 x 11mm
Weight9,8g
ColorBleu
Package1x EVERSOLO H1
1x Câble USB-C vers USB-C
1x Adaptateur USB-C vers USB-A
OutputJack 3.5mm
DAC / ADC ChipES9281AC
Max sampling rateDSD256
Max sampling rate384kHz
Max sampling rateMQA
ColorBlue
ClassClass A / AB
2 reviews
Moyen
Ayant eu la version au dessus qui n'est plus en vente sur le site je suis un peu déçu, déçu que lorsque j'ai voulu enlever le câble Jack tout l'ensemble intérieur du dac est venu avec... Obligé de recoller à la colle forte et surtout la galère à remettre les boutons de volume donc bon dac mais franchement fragile
This review has been posted for EVERSOLO H1 DAC Portable Headphone Amplifier ES9281AC Pro MQA 32bit 384kHz DSD256
Excellent petit DAC
Sur les conseils de David Aubert (que je remercie au passage), j'ai acquis ce petit DAC pour y connecter mon smartphone et des écouteurs Sennheiser IE200. Le son est bon et assez puissant. En y connectant un casque plus gourmand, c'est un peu faible mais ce n'etait pas mon objectif donc je suis très satisfait. Le DAC est petit et n'est pas génant dans une poche.
EVERSOLO offers with the H1 a compact and powerful portable DAC and headphone amplifier combo. With a USB-C input, it is an ideal companion for use...
