FIIO A1 Nomad Headphone Battery Amplifier TPA 6132/OPA2322
Reference : 10877
32,90 €tax incl.
27,42 € tax excl.
TheFIIO A1is a smart and faithful mobile nomad amp that amplifies the output of your smartphone or tablet. Its aluminum case testifies to the quality of construction of the brand. The small clip (clip back) makes it possible to "clip" on a belt for example.
With its 3.5mm stereo jack line-in jack and its 3.5mm jack output for a weight of 20g, the FIIO A1 is capable of holding a large number of headphones up to 100 Ohm.
Thanks to its dedicated electronic electronics (Integrated amplifier TPA 6130A2 and OPA 2322, ALPS potentiometer) it will meet many requirements.
In addition, an equalization function (4 positions) adjusts the bass response for better rendering of modern music (Trance, Dance, Electro, Dub).
The charge time of its lithium polymer battery is ultra short with less than 90 minutes(manufacturer's indications) with a simple USB charge of 5V. Here is a small smart headphone amplifier if you want to increase the quality of listening to your smartphone or tablet at a small price.
Main Features :
  • 3.5mm stereo jack input
  • 3.5mm stereo jack output
  • One micro USB input for 5V charge
  • Recommended headphone impedance: 16 ~ 100 Ohm
  • Output power: 78mW (on load of 16 Ohm)
  • Battery capacity 160mAh
  • Signal Noise Ratio: 100db (A-weighted)
  • Frequency response: 20hz ~ 20Khz
Dimensions:
  • 42 x 40.7 x 9.4mm
  • Weight: 20g (with back clip)
[Img-16427-left-thickbox_default]
[Img-16425-left-thickbox_default]
InputJack 3.5mm
OutputJack 3.5mm
ColorSilver
