FIIO BTR3 Bluetooth 4.2 Receiver Headphone Amplifier aptX HD LDAC LHDC CSR8675
The FiiO BT3 is a portable Bluetooth receiver with amplifier and headphone output, ideal for enjoying your music simply wirelessly. Particularly versatile, the BT3 supports all Bluetooth audio codecs: AAC, SBC, aptX, aptX LL, aptX HD, LDAC and LHDC. It is therefore compatible with all Bluetooth devices while being able to support high quality files up to 24bit 96kHz.
Reference : 14213
75,00 €tax incl.
62,50 € tax excl.
This product has been replaced by the new version, the FIIO BTR3K DAC 2xAK4377A.
FiiO BT3
Amplificateur Casque Récepteur Bluetooth 5.0 aptX HD LDAC LHDC CSR8675FiiO BT3 Amplificateur Casque Récepteur Bluetooth 5.0 aptX HD LDAC LHDC CSR8675
Complete Bluetooth support
LED Indicator
  • SBC : Blue flashing light
  • AAC ! Cyan flashing light
  • LDAC/DAC : White flashing/fixed light
  • LHDC : Green flashing light
  • aptX/aptX LL : Purple flashing light
  • aptX HD : Yellow flashing light
Qualcomm CSR8675
Bluetooth reception of the BT3 is based on a Qualcomm CSR8675 chip. It offers excellent audio performance, compatibility with all Bluetooth audio codecs and very low power consumption. It thus supports audio streams up to 24bit, thanks in particular to an integrated 120MHz DSP. This chip also provides a much more stable signal reception than other chips on the market.
AK4376A DAC / Headphone Amplifier
The BT3's Bluetooth chip is accompanied by a DAC AKM AK4376A DAC chip, offering very good sound performance, including an extremely low distortion level of -107dB and a high signal-to-noise ratio of 124dB. This chip also acts as a headphone amplifier and will allow you to enjoy a rich and accurate listening experience.
Long battery life
The BT3 hides a 300mAh battery that can be fully charged in just 1h30 and has a reading time of up to 11h!
Built-in microphone with noise cancellation
The amplifier integrated into the BT3 not only guarantees the quality of your music playback but also your phone calls. To improve call quality, the BTR3 is also equipped with Qualcomm cVc noise cancellation technology, which automatically adjusts the microphone and suppresses background noise.
Volume control
When a smartphone is paired with the FiiO BTR3, the volume levels of the two devices remain independent, providing two settings for more precise control. In addition, the BTR3 saves the last volume level used so that it does not have to be adjusted each time it is used.
NFC Pairing
The FiiO BTR3 can be paired very quickly and simply using NFC technology. A simple contact with the device to pair and you are ready to enjoy your music!
Bluetooth in your car
When driving, you can connect your smartphone to the BTR3 via Bluetooth and the BTR3 to your car's audio system via a 3.5mm jack cable. So you can enjoy your music on your car speakers, but also answer your calls safely.
Improve your audio system
If your audio system does not have Bluetooth connectivity, then the BTR3 is an ideal ally. Simply connect it to a Bluetooth source and then to your sound system with a 3.5mm jack cable to play your music wirelessly.
Siri iOS Compatibility
The BTR3 is compatible with the Siri Intelligent Voice Assistant, available on iOS systems. It is thus possible to activate Siri simply by double clicking on the multifunction button of the BTR3.
Fast reconnection
The BTR3 supports the quick reconnect function, allowing you to instantly pair the receiver to an Android device, simply by holding down the multifunction button on the BTR3 and enabling pairing on your smartphone.
USB DAC Mode
The BTR3 includes a USB-C connector, allowing both charging and operation in USB DAC mode. You can enjoy the decoding capabilities of the BTR3 on your computer, simply by plugging it into USB. No driver is required, the system is Plug & Play.
FiiO Music App
FiiO offers the FiiO Music application to install on your smartphone, allowing you to control the BTR3 remotely. This allows you to act on the balance, choose between 4 audio filters and offers a 10-band graphic equalizer.
Application FiiO Music Android
Application FiiO Music iOS
Design
The components of the BTR3 are integrated in a beautiful black aluminium alloy case, itself wrapped in 2.5D glass, similar to that used on the latest generation smartphones. This glass benefits from an oleophobic treatment that greatly reduces fingerprints. The BTR3 is particularly compact and lightweight, allowing it to be carried everywhere.
Ultra portable
Extremely compact, the BTR3 can therefore follow you on all your travels. It is delivered with a clip and a strap to attach it to a garment or a belt for example.
Product typeBluetooth amplifier
Bluetooth chipCSR8675
Bluetooth version4.2
Supported Bluetooth codecsAAC
SBC
aptX
aptX LL
aptX HD
LDAC
LHDC
Supported Bluetooth protocolsHFP
HSP
A2DP
AVRCP
Amplification / DAC chipAK4376A
Max. transmission distance30m
NFC Support5mm
Integrated microphone
InputsBluetooth
1x USB-C
Ouput1x Jack 3.5mm
USB DAC Mode
Battery capacity300mAh
Battey lifeApprox. 11h
Charging time<= 1h30 (5V DC 500mA)
Siri iOS compatibility
Recommanded headphone impedance16~100Ω
Output power25mW @ 32Ω
33mw @ 16Ω
Frequency response20Hz-20kHz (aptX)
20Hz-40kHz (LDAC)
THD+N< 0.003% (LHDC 1kHz)
Output impedance< 0.3Ω (32Ω load)
SNR120dB (A-Weighted)
Crosstalk>= 75dB (32Ω load)
Dimensions58 x 25 x 10.4mm
Weight26g
Package1x FiiO BT3
1x USB-C Cable
1x Lanyard
Frequency response curve 1
Test conditions : aptX HD connection, sinusoidal signal -5dB, 16bit 44.1kHz, 32Ω
  • Red curve: Left channel
  • Blue curve : Right channel
Frequency response curve 2
Test conditions : LHDC connection, sinusoidal signal -5dB, 24bit 192kHz, 32Ω
  • Red curve : Left channel
Frequency response curve 3
Test conditions : LDAC connection, sinusoidal signal -5dB, 24bit 192kHz, 32Ω
OutputJack 3.5mm
The FiiO BT3 is a portable Bluetooth receiver with amplifier and headphone output, ideal for enjoying your music simply wirelessly. Particularly...
