FIIO Q15 Portable Headphone Amplifier DAC
FiiO's Q15 portable DAC headphone amplifier is built using top-of-the-range components. Featuring the AKM AK4499EX and AK4191EQ chip combo, a third-generation XMOS XU316 interface and a Qualcomm QCC5125 Bluetooth 5.1 receiver chip, it supports high-resolution streams up to PCM 32bit 768kHz, DSD up to DSD512 and even MQA streams.
By buying this product you get 43 loyalty points
Reference : 18745
439,00 €tax incl.
365,83 € tax excl.
Shipping date: 22-04-2025.
FiiO Q15 Portable Headphone Amplifier DAC AK4499EX AK4191EQ XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512 MQA
FIIO Q15 picture
FiiO's Q15 portable DAC headphone amplifier is built using top-of-the-range components. Featuring the AKM AK4499EX and AK4191EQ chip combo, a third-generation XMOS XU316 interface and a Qualcomm QCC5125 Bluetooth 5.1 receiver chip, it supports high-resolution streams up to PCM 32bit 768kHz, DSD up to DSD512 and even MQA streams. On the Bluetooth side, the most reliable codecs are also supported, up to aptX Adaptive, aptX HD and LDAC. A handsome IPS color display is integrated into the robust casing for intuitive parameter adjustment, and a comprehensive connectivity interface is available. Indeed, the FiiO Q15 features a USB-C input and a coaxial SPDIF input, as well as two headphone outputs: 3.5mm jack and 4.4mm balanced jack. This enables the FiiO Q15 to meet a variety of needs, whether used with a CD player or your cell phone, all with a consistent power output that rivals that of some desktop headphone amplifiers with a much larger form factor.
FIIO Q15 highlights
FiiO Q15: high-end architecture
The FiiO Q15 circuit is designed on 5 levels (DAC - I/V converter - LPF - gain - headphone amplifier) for exemplary audio signal processing with extended dynamic range. The circuit is designed with variable gain and voltage logic to maximize performance. The different gain and voltage modes enable it to be adapted to any type of high-impedance in-ear or headphone available on the market.
FIIO Q15 architecture
FiiO Q15: carefully selected components
XMOS XU316 USB interface, high-precision crystal oscillators and the TI Cortex M4 processor provide exemplary digital-to-analog signal conversion. Processing of the incoming USB, coaxial and Bluetooth signal relies heavily on the TI Cortex M4 processor for high efficiency and extremely low latency. These components are complemented by the AKM AK4499EX and AK4191EQ chip combo, delivering top-level performance with SNR ≥ 123dB and THD +N < 0.0004%.
Les composants du FIIO Q15
Photo du FIIO Q15
FiiO Q15 : Bluetooth 5.1
A Qualcomm QCC5125 Bluetooth receiver chip enables the FiiO Q15 headphone amplifier to receive high-resolution streams wirelessly via various sources such as your computer, smartphone or tablet. High-fidelity Bluetooth codecs are supported: aptX, aptX HD, aptX Adaptative and LDAC. The Q15 is Hi-Res Audio Wireless certified, guaranteeing a high-quality wireless listening experience.
FiiO Q15: significant output power
The conversion stage of the FiiO Q15 portable DAC headphone amplifier uses ultra-low-noise components and numerous capacitors for a clear, transparent final sound restitution. This design enables it to develop up to 1600mW of power at 32 ohm on its balanced 4.4mm jack output, and up to 620mW of power at 3 ohm via its 3.5mm jack output. Moreover, a 5-level gain allows you to adapt the output power to match the characteristics of many headphones and IEMs on the market. The outputs can also be set to a line-out mode for coupling the FiiO Q15 DAC to a Hi-Fi amplifier.
La puissance de sortie du FIIO Q15
Photo du FIIO Q15 avec un téléphone portable
FiiO Q15: a 5500mAH battery for 9h autonomy
A 5500mAh battery provides 9h or 8h of autonomy, whether you use the Q15's unbalanced or balanced output. In addition, a switch enables you to switch the FiiO Q15 to phone mode for optimized operation when paired with your smartphone. Phone mode allows the FiiO Q15 to operate on its internal battery, saving your source's battery.
*For use with a computer, the FiiO Q15 must not be in phone mode.
FiiO Q15: EQ tuning for a personalized listening experience
The Q15 features 7 predefined and 3 customizable EQ presets. This allows you to personalize your listening experience to suit your tastes.
Photo de l'interface de réglage des EQ du FIIO Q15
Application FIIO control
FiiO Q15: a dedicated control app
The free FiiO Control App, available on both Android and iOS, lets you access numerous settings for the Q15 from your smartphone. You can modify the Bluetooth codec, change the operation of the device's LEDs or adjust the balance.
FiiO Q15 overview
Schéma de la connectique du FIIO Q15
1Phone mode switch
2Coaxial input
3USB-C input
4USB-C charging port
5Desktop mode switch
63.5mm headphone/line jack output
7Volume control knob
84.4mm headphone/line jack output
9Volume LED indicator
Product typePortable DAC headphone amplifier
DAC chipAKM AK4499EX + AK4191EQ
USB interfaceXMOS XU316
Bluetooth receiver chipQCC5125
Inputs1x SPDIF coaxial
1x USB-C
Outputs1x 3.5mm headphone/line jack output
1x 4.4mm balanced headphone/line output
Supported sampling ratesUSB : PCM 32bit 768kHz, DSD512, MQA
SPDIF coaxial : 24bit 192kHz, DSD DOP64
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD, aptX Adaptive, LDAC
Gain modeUltra high (in desktop mode, the power port is connected to the QC power supply) / super high / high / medium / low gain mode
Channel balance≤ 0.2dB
Recommended headphone impedanceUnbalanced : 8~150Ω
Balanced : 8~300Ω
ScreenIPS color with adjustable view
BatteryLithium 5500mAh
Charging time3.5h (PD fast charge)
Battery life9h: unbalanced output
8h : balanced output
PERFORMANCE MEASUREMENT @ 3.5MM HEADPHONE OUTPUT, USB DAC, COAX, ULTRA HIGH GAIN MODE
Output powerL+R ≥ 750mW+750mW (16Ω, THD+N < 1%)
L+R ≥ 625mW+625mW (32Ω, THD+N < 1%)
L+R ≥ 85mW+85mW (300Ω,THD+N < 1%)
SNR≥ 123dB (A-weighted)
Frequency response20Hz~80kHz: damping < 3dB
20Hz~20kHz: damping < 0.1dB
Output impedance< 1Ω
Crosstalk≥ 72dB
Peak output voltage14.5Vp-p
THD+N< 0.0005% (1kHz/-9dB @ 32Ω)
< 0.0004% (1kHz/-6dB @ 300Ω)
Noise floor<3.1uV (A-weighted)
PERFORMANCE MEASUREMENT @ 3.5MM HEADPHONE OUTPUT, USB DAC, COAX, SUPER HIGH GAIN MODE
Output powerL+R ≥ 520mW+520mW (16Ω,THD+N<1%)
L+R ≥ 400mW+400mW (32Ω,THD+N<1%)
L+R ≥ 55mW+55mW (300Ω,THD+N<1%)
SNR≥ 121dB (A-weighted)
Frequency response20Hz~80kHz: damping< 3dB
20Hz~20kHz: damping< 0.1dB
Crosstalk≥ 72dB
Peak output voltage11.5Vp-p
THD+N< 0.00045%(1kHz/-7dB @ 32Ω)
< 0.0004%(1kHz/-4dB @ 300Ω)
PERFORMANCE MEASUREMENT @ LINE OUTPUT JACK 3.5MM, USB DAC, COAX
THD+N< 0.00042% (1kHz/-4dB @ 10KΩ)
Crosstalk≥ 105dB
Output level2Vrms
Noise floor<1.6uV (A-weighted)
PERFORMANCE MEASUREMENT @ 4.4MM HEADPHONE OUTPUT, USB DAC, COAX, ULTRA HIGH GAIN MODE
Output powerL+R ≥ 635mW+635mW (16Ω,THD+N<1%)
L+R ≥ 1610mW+1610mW (32Ω,THD+N<1%)
L+R ≥ 340mW+340mW (300Ω,THD+N<1%)
Output impedance< 1.5Ω
Crosstalk≥ 113dB
Peak output voltage29Vp-p
THD+N< 0.00055% (1kHz/-14dB @ 32Ω)
< 0.0003% (1kHz/-2dB @ 300 Ω)
Noise floor<4.8uV (A-weighted)
PERFORMANCE MEASUREMENT @ 4.4MM HEADPHONE OUTPUT, USB DAC, COAX, SUPER HIGH GAIN MODE
Output powerL+R ≥ 675mW+675mW (16Ω,THD+N<1%)
L+R ≥ 1060mW+1060mW (32Ω,THD+N<1%)
L+R ≥ 215mW+215mW (300Ω,THD+N<1%)
Crosstalk≥ 113dB
Peak output voltage23Vp-p
THD+N< 0.00055% (1kHz/-13dB @ 32Ω)
< 0.00025% (1kHz/-4.5dB@300Ω)
PERFORMANCE MEASUREMENT @ LINE OUTPUT JACK 4.4MM, USB DAC, COAX
THD+N<0.00027%(1kHz/-5dB @ 10KΩ)
Crosstalk≥ 105dB
SNR≥ 126dB (A-weighted)
Output level4Vrms
Noise floor< 1.8uV (A-weighted)
Dimensions143.5 x 71.75 x 21.75mm
Weight310g
Package1x FiiO Q15 portable DAC headphone amplifier
1x USB-C to USB-C cable
1x USB-C to USB-A adapter
2x Telephone clamp
1x Storage pouch
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipAK4499EX
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
ClassN/A
FIIO Q15 Portable Headphone Amplifier DAC AK4499EX AK4191EQ XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512 MQA
FiiO's Q15 portable DAC headphone amplifier is built using top-of-the-range components. Featuring the AKM AK4499EX and AK4191EQ chip combo, a...
