Portable Headphone Amplifier 2x OPA NE5532
This FX-Audio PH-01 is a small portable headphone amplifier, simple but very powerful. Integrating an amplification circuit with two NE5532 AOPs mounted on DIP8 and therefore interchangeable, it offers a very nice musicality and a significant power gain. The amplifier also offers two gain levels (Low / High) to fit the vast majority of headphones. It is therefore perfectly adapted to offer a boost to a DAP or smartphone when you are on the move. Indeed, its small dimensions allow the PH-01 to easily slip into a pocket and be forgotten.
Warning: Opening the unit and changing the AOPs will void the warranty.
Product type | Headphone amplifier |
Input | 1x Jack 3.5mm |
Output | 1x Jack 3.5mm |
OPA | 2x AOP5532 (mounted on DIP8) |
Frequency response | 20Hz - 20kHz (+/-0dB) |
THD | 0.0001% |
SNR | 125dB |
Headphone output THD | 0.07% |
Output power | 65mW @ 16 Ohm, 89mW @ 32 Ohm, 95mW @ 64 Ohm, 69mW @ 120 Ohm, 29mW @ 300 Ohm |
Power supply (battery charge) | 5V 1A via Micro USB |
Dimensions | 9.5 x 5.3 x 1.3cm |
Weight | 75g |
Color | Black |
Package | 1x FX-Audio PH-01 1x Jack 3.5mm to Jack 3.5mm cable 1x USB-A to Micro USB cable |
