HIDIZS S9 PRO Portable Headphone Amplifier DAC ES9038Q2M Balanced 32bit 768kHz DSD512
Hidizs offers with its S9 Pro a revised version of the already excellent S9. The DAC and portable headphone amplifier combo is now based on the use of a high quality ES9038Q2M conversion chip, for a more than convincing sound restitution, thanks to an incredible precision
Reference : 15392
109,00 €tax incl.
90,83 € tax excl.
Hidizs S9 Pro
Hidizs S9 Pro Amplificateur DAC Portable ES9038Q2M Symétrique 32bit 768kHz DSD512
Hidizs offers with its S9 Pro a revised version of the already excellent S9. The DAC and portable headphone amplifier combo is now based on the use of a high quality ES9038Q2M conversion chip, for a more than convincing sound restitution, thanks to an incredible precision. In addition, the device supports high sampling rates and has a dual balanced and unbalanced output to suit all uses.
Hidizs S9 Pro, S9 and S8 comparison
S9 Pro
S9
S8
DAC
ES9038Q2M
AK4493EQ
CS43131
Outputs
Jack 3.5mm + Jack 2.5mm
Jack 3.5mm
Light indicator
Yes
Yes
No
Max PCM sampling rate
32bit 768kHz
32bit 768kHz
32bit 384kHz
Max DSD sampling rate
DSD512
DSD512
DSD256
SNR
Jack 3.5mm : 120dB @ 32Ω
Jack 2.5mm : 119dB @ 32Ω
Jack 3.5mm : 119dB @ 32Ω
Jack 2.5mm : 117dB @ 32Ω
120dB
Channel separation
Jack 3.5mm : 80dB @ 32Ω
Jack 2.5mm : 118dB @ 32Ω
Jack 3.5mm : 79dB @ 32Ω
Jack 2.5mm : 114dB @ 32Ω
78dB @ 32Ω
THD+N
Jack 3.5mm : 0.0006% @ 32Ω
Jack 2.5mm : 0.0012% @ 32Ω
Jack 3.5mm : 0.0018% @ 32Ω
Jack 2.5mm : 0.006% @ 32Ω
0.002% @ 1kHz
Output power
Jack 3.5mm : 100mW @ 32Ω
Jack 2.5mm : 200mW @ 32Ω
Jack 3.5mm : 90mW @ 32Ω
Jack 2.5mm : 120mW @ 32Ω
ES9038Q2M DAC
Comparison Hidizs S9 Pro, S9 and S8
PCM up to 32bit 768kHz
Hi-Res certified, the S9 Pro supports high sampling rates. It can read PCM files up to 32bit 768kHz.
Native DSD up to DSD512
In the same way, the S9 Pro also supports Native DSD. It will allow you to enjoy your files up to DSD512.
Jack 3.5mm & Jack 2.5mm outputs
The S9 Pro is equipped with a double headphone output. There is a 3.5mm unbalanced jack and a 2.5mm balanced jack. Therefore, whatever the headphones used, the S9 Pro will be able to accompany your listening sessions with ease.
Light indicator
The body of the S9 Pro is dressed with an LED indicator, hidden under the logo of the brand. It changes color to indicate the sampling rate of the file being played.
  • Yellow : DSD64/128
  • Purple : DSD256/512
  • Blue : PCM 176.4/192kHz
  • Red : PCM 352.8/384kHz
  • White : PCM 705.6/768kHz
  • Green : PCM 44.1/48/88.2/96kHz
Comfortable output power
The Hidizs S9 Pro benefits from an output stage allowing it to develop a comfortable power to feed many headphones of the market. Thus, its unbalanced output on Jack 3.5mm allows to take advantage of a power of 100mW, where its balanced output Jack 2.5mm develops 200mW.
Robust and design aluminum body
All the components of the S9 Pro are integrated in a beautiful CNC machined aluminum case, both robust and design.
Hidizs S9 Pro Amplificateur DAC Portable ES9038Q2M Symétrique 32bit 768kHz DSD512 Hidizs S9 Pro Amplificateur DAC Portable ES9038Q2M Symétrique 32bit 768kHz DSD512
Product typePortable headphone amplifier and DAC
DAC ChipESS ES9038Q2M
Supported sampling ratesPCM up to 32bit 768kHz
Input1x USB-C
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 2.5mm
Compatible OSWindows, Mac OS, iPad OS, Android, iOS (avec câble Lightning OTG)
Recommanded headphone impedance8-300Ω
Single-ended headphone output
Output power100mW @ 32Ω
Frequency response20Hz - 50kHz
SNR120dB @ 32Ω
Channel separation80dB @ 32Ω
THD+N0.0012% @ 32Ω
Balanced headphone output
Output power200mW @ 32Ω
SNR119dB @ 32Ω
Channel separation118dB @ 32Ω
THD+N0.0006% @ 32Ω
Body materialCNC machined aluminum
Dimensions59 x 18 x 8mm
Weight11g
Package1x Hidizs S9 Pro
1x USB-C Cable
1x USB-C to USB-A adapter
1x Rear clip
OutputJack 2.5mm
OutputJack 3.5mm
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Max sampling rateDSD512
Excellent
J'ai donné mon S9 à mon fils, je l'ai donc remplacé par le S9 pro. Je n'ai malheureusement pas pu les comparer en direct, de toutes manières je ne pense pas avoir les oreilles assez affutées pour percevoir la différence. Mais je suis ravi par la qualité du S9 pro. Je l'utilise principalement connecté entre mon smartphone Samsung et mon casque Grado SR325x. Parfait. Livraison parfaite par Audiophonics que je remercie pour la qualité de leurs produits.
This review has been posted for HIDIZS S9 PRO Portable Headphone Amplifier DAC ES9038Q2M Balanced 32bit 768kHz DSD512
Hidizs offers with its S9 Pro a revised version of the already excellent S9. The DAC and portable headphone amplifier combo is now based on the use...
