iBasso DC ELITE DAC Headphone Amplifier
The Ibasso DC-Elite is the miniature version of the DX320 Max. In fact, the components and architecture of this portable DAC/headphone amplifier are inspired by the DAP DX320 Max. It incorporates a RHOM BD34301EKV DAC chip, FGPA and NDK femtosecond oscillator.
By buying this product you get 44 loyalty points
Reference : 18544
449,00 €tax incl.
374,17 € tax excl.
Shipping date: 18-04-2025.
IBASSO DC ELITE DAC / Portable Headphone Amplifier BD34301EKV 32bit 768kHz DSD512
Photo of IBASSO DC ELITE Portable DAC / Headphone Amplifier
The Ibasso DC-Elite is the miniature version of the DX320 Max. In fact, the components and architecture of this portable DAC / headphone amplifier are inspired by the DAP DX320 Max. It incorporates a RHOM BD34301EKV DAC chip, FGPA and NDK femtosecond oscillator to achieve a considerable reduction in jitter and distortion. Thanks to its circuit design, it consumes little power and still develops power of up to 280mW @ 32Ω on its balanced 4.4mm jack output and 162mW @ 32Ω on its unbalanced 3.5mm jack output. Input is via USB-C connector.
Ibasso DC Elite: a ROHM BD34301EKV DAC chip
Ibasso has chosen to integrate a RHOM BD34301EKV DAC chip to greatly enhance the dynamic range of the DC Elite DAC / Portable Headphone Amplifier, giving it a wide soundstage. Coupled with the DC Elite's ingenious circuit design, this DAC chip contributes to making it a high-performance high-fidelity device.
Photo of the ROHM 34301EKV DAC chip
Photo of NDK Femtosecond oscillator + FGPA
Ibasso DC Elite: NDK femtosecond oscillator + FGPA
The DC-Elite benefits from a FGPA algorithm developed in-house by Ibasso. Its very low level of jitter and distortion is made possible by the use of an NDK femtosecond oscillator, which considerably improves the quality of sound reproduction.
iBasso DC Elite; 24-position, 4-section volume control
Ibasso has completely updated the traditional 24-position volume control. As with the DX320 Max, the DC-Elite benefits from a miniaturized stage potentiometer. This type of potentiometer is generally used on high-end amplifiers. The DC Elite achieves an SNR of 96.3dB. The sound of each channel is precisely controlled, with a difference of just +/-0.1dB.
Ibasso DC Elite volume control
Ibasso DC Elite: high-fidelity architecture
The DC Elite adopts a complete player architecture with ultra-low-noise LDOs, FGPA, DAC, I/V converter, low-pass filter, volume control and amplifier stage. It incorporates no fewer than 6 operational amplifiers and delivers excellent sound reproduction.
Ibasso DC Elite architecture
Ibasso DC Elite power supply
Ibasso DC Elite: a clean, stable power supply
This portable DAC/headphone amplifier features not only a synchronous DC-DC converter, but also numerous ultra-low-noise LDOs. This enables the power supply system to achieve a noise level of just 0.8uV, with an output current of up to 500mA to power the Ibasso DC Elite.
Ibasso DC Elite: LED indicators
A LED on one side of the DC Elite indicates its operating status: red for standby, green for PCM, blue for DSD and white for coaxial output.
Ibasso DC Elite LED indicator
Outputs of the Ibasso DC Elite portable DAC / Headphone amplifier
Ibasso DC Elite: 3 types of output
The DC Elite features 3 outputs: a balanced jack 4.4mm headphone output, a single-ended jack 3.5mm headphone output and a coaxial output on the same 3.5mm jack. In fact, the 3.5mm jack interface is capable of transmitting SPDIF coaxial signals for direct connection of the DC Elite to an external DAC. To do this, simply apply a long press to the volume knob. The LED indicator turns white.
Ibasso DC Elite: a control application
The proprietary Ibasso UAC APP has been updated for full compatibility with the DC Elite. It gives you access to 4 levels of PCM volume reduction, 2 digital filter options and 20 levels of L/R channel balance.
UAC APP
Dimensions of the Ibasso DC Elite
Product typePortable DAC / Headphone amplifier
DAC ChipROHM  BD34301EKV
Input1x USB-C
Outputs1x Jack 4.4mm balanced headphone output
1x Jack 3.5mm headphone output + optical output
Supported sample ratesPCM up to 32Bit 768kHz
DSD up to DSD512
Optical outputUp to 32Bit 768kHz
System compatibilityiOS and Android 5.1 and + (without driver)
Mac, Windows 10, Windows 11 (plug and play)
Windows XP, Windows 7, Windows 8 (with driver)
BALANCED Jack 4.4MM HEADPHONE OUTPUT MEASURES
Output voltage4.6Vrms
Output power280mW @ 33 Ohm
70mW @ 300 Ohm
THD+N0.00022% (@ 300 Ohm)
0.00031% (@ 32 Ohm)
Fréquency response10Hz - 50KHz (-0.5dB)
S/N121dBA
Dynamic range118dBA
Noise floor3.5uVrms (Normal listening volume <0.9uV)
Output impedance< 0.4 Ohm
Single-ended Jack 3.5MM HEADPHONE OUTPUT MEASURES
Output voltage2.28Vrms
Output voltage162mW @ 32 Ohm
THD+N0.00028% (@ 300 Ohm)
0.00056% (@ 32 Ohm)
S/N117dBA
Dynamic range115dBA
Noise floor2.4uV (Normal listening volume <0.8uV)
Output impedance< 0.2 Ohm
Power supplyVia USB-C connector
Dimensions64 x 35 x 14.5mm
Net Weight60.5g
Package1x DAC / Headphone amplifier Ibasso DC Elite
1x USB-C to Lightning cable
1x USB-C to USB-C cable
1x USB-C to USB-A adapter
1x Leather storage pouch
OutputJack 3.5mm
OutputJack 4.4mm
OutputCoaxial SPDIF
DAC / ADC ChipROHM BD34301EKV
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
ClassN/A
QUALITE INATTENDUE
Je ne savais pas trop quelle qualité attendre et c'est donc une immense surprise. Restitution de tres haut niveau, douceur incroyable, dynamique et surtout quelle scene sonore !!! avec mon senheiser ie 900 c'est le fameux son "hors de tete" qui est surprenant. L'image et la séparation sont de tres haut niveau. supérieur à ma Cobalt (deux fois plus cher en même temps) mais aussi à mon DAP Astell kern SE 200. C'est tellement bon que j'utilise le DAP uniquement en streamer et je sors en usb bit pertect dans le DC ELITE. Une de mes plus belles surprises de ces 10 dernières années en hifi nomade.
This review has been posted for IBASSO DC ELITE Portable DAC Headphone Amplifier BD34301EKV 32bit 768kHz DSD512
The Ibasso DC-Elite is the miniature version of the DX320 Max. In fact, the components and architecture of this portable...
