IBASSO PB5 Portable Headphone Amplifier
The iBasso PB5 is a portable analog headphone amplifier based on a balanced structure and the use of audiophile components. Its preamplification stage is based on Nutube 6P1 tubes, while its amplification stage uses OPA827 and VCEsat transistors. A hybrid design, it offers the smoothness and warmth of tubes coupled with the power of more modern components for a power output of up to 2x1700W @ 32 ohms.
By buying this product you get 148 loyalty points
Reference : 20422
1 489,00 €tax incl.
1 240,83 € tax excl.
iBasso PB5 Balanced Portable Headphone Amplifier Nutube 6P1 Tubes 2x1700mW @ 32 ohm
Photo of iBasso PB5
The iBasso PB5 is a portable analog headphone amplifier based on a balanced structure and the use of audiophile components. Its preamplification stage is based on Nutube 6P1 tubes, while its amplification stage uses OPA827 and VCEsat transistors. A hybrid design, it offers the smoothness and warmth of tubes coupled with the power of more modern components for a power output of up to 2x1700W @ 32 ohms. Added to this are gain control, a 24-position volume control and no less than 6 batteries for up to 10h30 autonomy. As for the interface, there's a 4.4mm jack input and two outputs, a 3.5mm jack output and a balanced 4.4mm jack output. All in all, the iBasso PB5 OSPREY offers a high level of compatibility while preserving exceptional sound quality.
iBasso PB5 in action
iBasso PB5: tube preamplifier stage
The preamplifier stage of the iBasso PB5 benefits from two sixth-generation Nutube tubes developed by Korg and Noritake. These two tubes behave like traditional triode tubes, bringing rich, warm tones while maintaining exceptional linearity. Ibasso has also taken care to place these tubes on a suspension mechanism to limit microphonic effects, so that they can offer a pure, transparent rendering.
Photo of the iBasso PB5 pre-amplification stage
Photo of the iBasso PB5's OPAs and transistors
iBasso PB5: high-power amplifier stage
Based on Texas Instrument OPA827 and VCEsat transistors, the iBasso PB5 portable headphone amplifier delivers up to 2x1700mW @ 32 ohm. This offers a high level of compatibility, thanks to the ability to drive headphones or IEMs with impedances ranging from 8 to 600 ohm. This translates into an output voltage of up to 9Vrms on the PB5's balanced output, and up to 4.5Vrms on its unbalanced output.
iBasso PB5: precise volume control and gain adjustment
iBasso PB5 volume control
Volume control
A 24-position, 4-section potentiometer provides extremely precise volume control. This analog volume control preserves the rendering of the preamplifier stage tubes within the PB5.
iBasso PB5 gain adjustment
2 levels of gain adjustment
Two levels of gain adjustment (Low: +2dB / High: +11.5dB) provide additional adjustment to ensure the iBasso PB5's compatibility with many headphones and IEMs on the market.
iBasso PB5: a 6-battery design
The iBasso PB5 integrates no fewer than 6 batteries, 2 of which power its preamplifier stage, while the other 4 power its amplifier stage. This arrangement greatly preserves the final sound reproduction while offering up to 10h30 of autonomy, making the PB5 the perfect ally for your travels. Power is supplied via a 5V USB-C port.
Please note that the USB PD protocol is not supported by the iBasso PB5's USB-C power port. Charging is via standard USB or QC.
Photo of iBasso PB5 batteries
iBasso PB5 overview
iBasso PB5 overview
1Balanced 4.4mm headphone output
23.5mm headphone output
3Balanced 4.4mm headphone input
4Volume control
5Power switch
6Gain adjustment
7USB-C 5V power port (Standard or QC)
Product typePortable headphone amplifier
ConceptionHybrid balanced structure
Tubes2x sixth-generation Nutube 6P1
AOPOPA827
TransistorsVCEsat
Input1x Balanced 4.4mm jack
Output1x Balanced 4.4mm jack
1x 3.5mm jack
Output voltage4.4mm jack : 9Vrms
3.5mm jack : 4.5Vrms
Output power1700mW+1700mW @ 32 ohm
Line input voltage<2.5Vrms
Output impedance4.4mm jack: 0.25 ohm
3.5mm jack: 0 ohm
Frequency response20Hz-40kHz (+0.5dB/-2dB)
Recommanded impedance8-600 ohm
GainHigh gain : +11.5dB
Low Gain : +2dB
Volume adjustment
Power supply portUSB-C
Charging time2h50
Autonomy10h30
Dimensions139 x 82 x 28mm
Weight352g
Package1x iBasso PB5 portable headphone amplifier
2x 4.4mm jack cable
1x USB-A to USB-C cable
InputJack 4.4mm
OutputJack 3.5mm
OutputJack 4.4mm
ClassN/A
The iBasso PB5 is a portable analog headphone amplifier based on a balanced structure and the use of audiophile components. Its preamplification...
