IFI AUDIO IDSD DIABLO 2 Portable Headphone Amplifier DAC
With the iDSD Diablo 2, iFi Audio is offering a portable DAC and dual-mono headphone amplifier with an output power of up to 5180mW and which supports signals up to PCM 768kHz, DSD512 and MQA. The latter is equipped with a Qualcomm Bluetooth 5.4 chip supporting the new aptX Lossless codec and has been designed to be compatible with xMEMS driver technology.
By buying this product you get 127 loyalty points
Reference : 19871
1 279,00 €tax incl.
1 065,83 € tax excl.
iFi Audio iDSD Diablo 2 Balanced Portable Headphone Amplifier DAC Burr-Brown Bluetooth 5.4 aptX Lossless 768kHz DSD512 MQA
Photo of IFI Audio iDSD Diablo 2
With the iDSD Diablo 2, iFi Audio is offering a portable DAC and dual-mono headphone amplifier with an output power of up to 5180mW and support for signals up to 32bit 768kHz PCM, DSD512 and MQA. It is equipped with a Qualcomm Bluetooth 5.4 chip, supports the new aptX Lossless codec and has been designed to be compatible with xMEMS speaker technology.
iFi Audio iDSD Diablo 2: Support for xMEMS speaker technology
The predecessor of the Diablo 2 was the first to support xMEMS solid-state microdriver technology, and this headphone amplifier follows in its footsteps. This new technology requires certain technical features from the amplifier to be compatible, such as a high output voltage and a specially configured 4.4mm jack port. This method offers significant benefits in return.
IFI AUDIO iDSD Diablo 2: Close-up of the facade
Firstly, the mechanical response of this type of loudspeaker is just 15µsec, 150 times faster than a conventional loudspeaker. What's more, they have a flat phase response of 2°, giving ultra-precise, spatialised sound. Finally, the silicon used as the diaphragm in xMEMS loudspeakers is much more rigid than the plastic often used in more conventional loudspeakers, providing greater resistance and much better midrange reproduction.
iFi Audio iDSD Diablo 2: An amplifier for all headphones
The Diablo 2 has been designed to drive even the most power-hungry helmets. In fact, it has 3 modes to adapt to all situations. First, there's the Normal mode, mainly useful for headphones, which are generally equipped with low-demand speakers. Next comes Turbo mode, designed for medium-sensitivity headphones. Finally, Nitro mode, with an output level of 19.2V, for the most demanding headphones.
De plus, il vous est possible d’activer la fonctionnalité propriétaire de la marque, iEMatch, via un interrupteur présent en dessous de l’appareil. Cela permet à vos casques et écouteurs à haute sensibilité de profiter d’un bruit de fond réduit et d’une augmentation de la plage de volume utilisable.
IFI AUDIO iDSD Diablo 2: Close-up of the iEMatch switch
iFi Audio iDSD Diablo 2: Bluetooth 5.4
Thanks to the use of a Qualcomm Bluetooth 5.4 QCC518x chip, the Diablo 2 is able to support the new aptX Lossless codec, which offers a maximum data rate of 1200kbps. In comparison, aptX Adaptive offers a maximum bit rate of 420kbps, while LDAC offers a bit rate of 990kbps.
IFI AUDIO iDSD Diablo 2: USB-C power and data port
iFi Audio iDSD Diablo 2: Details that make all the difference
Examining the Diablo 2's front panel, you'll find a new volume lock button, next to the volume control, which prevents accidental changes during transport. You'll also notice that power and data input via USB-C have been separated to ensure a perfectly clean signal.
iFi Audio iDSD Diablo 2: A host of proprietary technologies
The Diablo 2 features PureWave, Servoless DirectDrive, OptimaLoop and Advanced Jitter Reduction technologies, delivering exceptionally pure, detailed sound.
PureWave's fully symmetrical dual-mono circuit improves clarity by separating channels and reducing noise. DirectDrive eliminates the need for coupling capacitors, ensuring a cleaner sound. OptimaLoop uses multiple custom feedback circuits in the amplifier stage, refining gain control and reducing distortion. Finally, the femto GMT clock using Smart cache memory minimizes phase noise.
iFi Audio iDSD Diablo 2: Silent power supply
The Diablo 2 can be powered by battery or mains. Battery power provides clean, stable DC power, avoiding the problems associated with mains power, such as dips, spikes and noise-generating RFI/EMI pollution. However, to ensure that mains power can still be used satisfactorily, the Diablo 2 is equipped with the iPower2 power supply featuring Active Noise Cancellation II technology, which effectively cancels all incoming EMI and RFI noise, making it over 10 times quieter than most audiophile power supplies.
IFI AUDIO iDSD Diablo 2 : PCB and battery
iFi Audio iDSD Diablo 2 package
iFi Audio iDSD Diablo 2 presentation diagram
1xMEMS ON/OFF mode switch
2LED indicator Operating mode / Source / Audio format / Bluetooth codec
3Single-ended Jack 6.35mm headphone output
4Balanced Jack 4.4mm headphone output
5Output level switch
6Volume lock
7ON/OFF and volume button
8Input switch
9Balanced 4.4mm jack line output / Single-ended line input
10SPDIF Coaxial/Optical input 3.5mm jack
11USB-C charge input
12USB-C input
Product typePortable DAC
Portable headphone amplifier
INputs1x USB-C
1x Coaxial / Optical SPDIF (Jack 3.5mm)
1x Single-ended line input
Bluetooth 5.4
Outputs1x Balanced Jack 4.4mm headphone output
1x Single--ended Jack 6.35mm headphone output
1x Balanced Jack 4.4mm line out
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
MQA
SNR≥ 114dB(A)
Dynamic range≥ 114dB(A)
THD+N0.002% @ 0dBFS 200kΩ
Max output level / powerJack 4.4mm : 19.2V/611mW @ 600Ω / 12.87V/5180mW @ 32Ω
Jack 6.35mm : 9.6V/153mW @ 600Ω / 8.85V/2450mW @ 32Ω
xMEMS : 28Vpp (Sortie Jack 4.4mm)
RMS output level / powerJack 4.4mm : 19.2V/611mW @ 600Ω / 7.4V/1710mW @ 32Ω / 11.5V/2060mW @ 64Ω
Jack 6.35mm : 9.6V/153mW @ 600Ω / 8.1V/2050mW @ 32Ω / 9.3V/1360mW @ 64Ω
Output impedance≤ 200Ω
ConsumptionNitro : 12W
Turbo : 5W
Normal : 2W
xMEMS : 8W
BatteryLithium-polymer 4800mAh
Weight455g
Dimensions166 x 85 x 28.5mm
ColorRed
Conditionnement1x iFi Audio iDSD Diablo 2
1x Carrying case
1x Power supply
1x USB-C to USB-C cable
1x Jack DC to USB-C adapter
1x Jack 3.5mm to Jack 6.35mm adapter
1x USB-A to USB-C adapter
1x Toslink to Mini-Toslink adapter
InputOptical Mini-Toslink
OutputJack 6.35mm
OutputJack 4.4mm
DAC / ADC ChipBurr Brown
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
ColorRed
ClassN/A
IFI AUDIO IDSD DIABLO 2 Balanced Portable Headphone Amplifier DAC Burr-Brown Bluetooth 5.4 aptX Lossless 768kHz DSD512 MQA
With the iDSD Diablo 2, iFi Audio is offering a portable DAC and dual-mono headphone amplifier with an output power of up to 5180mW and which...
