SHANLING UP4 Portable Headphone Amplifier DAC Balanced 2x ES9218P Bluetooth 5.0 CSR8675
Compact, affordable, yet high-performance, the Shanling UP4 is a DAC combo and portable symmetrical headset amplifier with Bluetooth 5.0 connectivity. It will accompany your smartphone or DAP to reveal its full potential, wherever you are.
4.5 / 5
Reference : 15021
89,00 €tax incl.
74,17 € tax excl.
This product has been replaced by the new version, the SHANLING UP4 2022 Portable DAC 2x ES9219C.
Shanling UP4
Shanling UP4 Amplificateur Casque DAC Portable Symétrique 2x ES9218P Bluetooth 5.0 CSR8675
Ultimate Connectivity
The UP4's high-performance Bluetooth 5.0 connectivity is compatible with the standard AAC and SBC codecs, as well as the high-definition codecs aptX, aptX HD, aptX LL, HWA LHDC and LDAC. These last codecs enable high-quality audio transmission that can match or exceed CD quality in wireless applications. The UP4 benefits from the dual certification of Hi-Res Audio and Hi-Res Audio Wireless.
On its front panel, an LED indicator displays in real time the transmission codec used.
  • LDAC : Green
  • aptX / aptX LL : Violet
  • SBC : Blue
  • HWA : White
  • aptX HD : Yellow
  • AAC : Cyan
ES9218P Dual DAC / Amplifier
At the heart of the Shanling UP4 are two ESS Sabre ES9218P chips. The latter, which are responsible for both digital/analog conversion and signal amplification, provide a clear and detailed reproduction, while developing considerable power with a low output impedance. One chip is used for each channel.
In addition, the UP4 can also be used with a computer in USB DAC mode. Once connected via its USB-C connector, the UP4 becomes a very good sound card.
Balanced output
Connect your headphones or earphones to the balanced 2.5mm jack output to enjoy the full potential of the two ES9218P chips. This balanced output provides more power, more detailed sound reproduction, and better channel separation.
Gain Control & Digital Filters
The UP4 allows you to simply select a gain level (Low, High and Dual DAC/Boost) and one of four digital filters available. It is thus capable of adapting to your listening and your equipment in an instant.
Dual DAC Mode
Dual DAC mode allows the UP4 to use its two ES9218P chips to get more output power, even with standard headphones and on its unbalanced 3.5mm jack output.
Bluetooth 5.0
The Bluetooth connectivity of the Shanling UP4 is entrusted to a Qualcomm CSR8675 chip. The latter ensures excellent signal transmission, fast and stable, while minimizing latency and offering better resistance to interference.
High degree of autonomy
With a battery of 550mAh, the UP4 offers a significant autonomy, allowing long listening without interruption. Thus, it can be used continuously for 15 hours in asymmetrical and 10 hours in symmetrical. In standby, its autonomy is 300h.
High quality microphone
Featuring a high quality, 8th generation Knowles SiSonic microphone, the UP4 will allow you to answer calls received directly on your connected smartphone. Taking advantage of dVc noise cancellation technology, your voice will become clearer and more audible, even in noisy environments.
NFC pairing
An NFC chip allows fast pairing of your smartphone to the Shanling UP4. All you need to do is to bring the two devices closer together so that the connection can be made in a fraction of a second.
To be used, this function requires that your smartphone is also NFC compatible.
1LED indicator
2Multifunction rotary knob
3NFC sensor
4Jack 3.5mm single-ended output
5Jack 2.5mm balanced output
6Microphone
7Mode button
8USB-C Connector
Product typePortable headphone amplifier and DAC
InputBluetooth 5.0
Outputs1x Jack 2.5mm balanced output
1x Jack 3.5mm single-ended output
Other connectors1x USB-C (Chraging / USB DAC)
Bluetooth chipQualcomm CSR8675
DAC / Amplification chip2x ESS Sabre ES9218P
Supported Bluetooth codecsLDAC, HWA (LHDC), aptX HD, aptX LL, AAC, SBC
Transmission distance10m
MicrophoneKnowles SiSonic
Power71mW @ 32Ω, single-ended output, high gain
91mW @ 32Ω, single-ended output, Dual DAC mode
160mW @ 32Ω, balanced output
SNR120dB (single-ended)
120dB (balanced)
Channel separation73dB @ 32Ω, single-ended
96dB @ 32Ω, balanced
THD+N0.003% @ LDAC, A-Weighting, 0.5V, 32Ω
0.03% @ 0.5V, A-Weighting, 32Ω
Autonomy15h @ single-ended
10h @ balanced
Charging time2h
Battery550mAh
Supply voltage5V DC 500mA
Dimensions60 x 36 x 13.5mm
Weight37g
Package1x Shanling UP4
1x USB-C cable
1x Clip case
Input
  • Bluetooth
  • USB
Output
  • Jack 2.5mm
  • Jack 3.5mm
  • USB
Color
  • Black
Remote Control
  • No
2 reviews
Ultra pratique
Cela fait maintenant quelque mois que j'utilise ce produit. Principalement connecté sur un système d'enceinte portable et via la prise jack simple. Je précise du coup, car je l'utilise pas vraiment dans son usage principal d'écoute au casque. Mais du coup premier point super, c'est la porté. Elle est vraiment excellente en comparaison à d'autre produit que j'ai pu testé, pour moi c'est important car je peux aller d'un bout à l'autre du jardin, ou de la maison sans que cela déconnecte, très agréable à l'usage. L'autonomie est bonne aussi. L'ergonomie est chouette, notamment la connexion rapide, il va même démarrer automatiquement la musique qu'on était en train d'écouter. Moi j'apprécie. La molette très agréable aussi. L'application s'avère utile, un égaliseur de disponible pour un réglage fin, c'est pas un égaliseur de bourrin, et c'est bien comme ça. Sélection de type de traitement (filtre) des haut fréquence, je ne pensais pas que ça me serait utile au départ, j'ai appris à les utiliser selon les besoins des système et il s'avère bien de les avoir quand on bricole, ou change de système régulièrement. Mode de gain intéressant, pareil j'ai eu des périodes high gain qui a la plus grand dynamique à mon sens, le dual dac boost qui peut être utile en soirée quand on recherche un son un peu compressé, et le low gain, je l'utilise actuellement quand je recherche vraiment à faire ressortir les basses. Comme j'écoute surtout sur un système d'enceinte amplifié, je ne peux pas juger de la puissance pour driver les casques, mais du peu que j'ai testé, y'a de quoi faire. En ce qui concerne la qualité de son, je l'utilise en LDAC, je dois avouer que le son a la pêche, c'est dynamique c'est sûr, c'est très bon pour le prix, mais dans la même gamme de prix, le topping BC3 m'a paru meilleurs en terme de scène sonore et de naturel, que ce soit au casque et sur un système d'enceinte. après une note importante à préciser, j'ai testé uniquement sur la prise jack standard en high gain. Je n'ai pas actuellement de quoi testé la prise TSR, donc peut être que cela vient améliorer justement la perception de la scène sonore. Mais bon avec l'application, la compacité, la fiabilité de construction et de connexion, je suis très satisfait, je recommande.
This review has been posted for SHANLING UP4 Portable Headphone Amplifier DAC Balanced 2x ES9218P Bluetooth 5.0 CSR8675
Bon amplificateur
Bon produit qui offre un son dynamique, plutôt enthousiasmant contenu de son utilisation en bluetooth. L'attache vestimentaire n'est pas très pratique. Toutefois, je recommande ce petit amplificateur, un des meilleurs dans sa catégorie. La livraison par chronopost a été une fois de plus lamentable avec un délai non respecté.
Compact, affordable, yet high-performance, the Shanling UP4 is a DAC combo and portable symmetrical headset amplifier with Bluetooth 5.0...
